Install DSM Injectors
Old Apr 4, 2003 | 02:51 AM
BlackB18CTeg's Avatar
Default Install DSM Injectors
Does anyone know how to install DSM injectors with the resistor pack?
Old Apr 9, 2003 | 12:48 PM
Default Re: Install DSM Injectors (BlackB18CTeg)
anyone? I got them today and I need help
I have a 95 INtegra GSR
Old Apr 10, 2003 | 12:51 PM
no one knows how?
Old Apr 10, 2003 | 01:40 PM
jabroni95gsr's Avatar
This f*cking integra forum is becoming more worthless by the day....now its just cluttered with the same crap over and over with no hard tech stuff...for future reference, try the drag racing or forced induction forums...
now before i tell you, how are you controlling these injectors? you can't just put them in for a couple of reasons...1) you have to be able to control them, just flowing more fuel will not make power 2) you need a resistor box, PM "sonny" he can get you one with wiring instructions. the reason why you need this is because the stock injectors are saturated and the dsm are peak and hold...two different types of injectors. WHy are you upgrading? Do you have hondata? VAFC hack? turbo?
Now for the installation. In terms of parts, you need OBD1 clips (which you have) and 96+ SOHC civic injector spacers (which sit in the manifold). Use the stock O rings from the DSMs. Now, on the part of the injector that plugs in, you will see a ridge inside the plug. grind that away...much like you would if you were doing the 9005 light conversion. With that done, use the parts and just put it all together.
Good luck.
Old Apr 10, 2003 | 01:50 PM
Default Re: Install DSM Injectors (jabroni95gsr)
I running Turbo, if anyone has a wiring diagram of resistor box, PM me.
Old Apr 10, 2003 | 05:19 PM
First of all YOUR WELCOME. Get in the habit of thanking people when they give you information...
Second of all, go to hondata.com and they have a wiring diagram.
Old Apr 10, 2003 | 05:37 PM
my bad, Thank you, if you look at my other posts i usually say thanks.
Old Apr 13, 2003 | 02:13 PM
my resistor box has 7 wires (6 black and 1 red) I am assuming it was for 6 cylinder, but can i just not use 2 of them and be fine?
Old Apr 13, 2003 | 08:00 PM
hollaback6's Avatar
yes you can just use 4 of the black wires.
Old Apr 15, 2003 | 11:58 AM
98TEGLS's Avatar
Default Re: Install DSM Injectors (hollaback6)
let me know what you think about the dsm injectors my.. well call him ex friend installed them in his hatch and hated them! T.I.A
93grayeg
Jan 9, 2010 02:19 AM
Black R
Jan 2, 2005 06:31 PM
nonemulatory
Dec 2, 2004 11:07 AM
digitalhav0c
Apr 4, 2003 06:15 AM
Pinhead
May 27, 2002 07:42 AM
