HELP! Roof is leaking
or the sunroof is. I taped up the whole sunroof but water still gets inside. Is it the gutters? or the weather sealing? help! it rains like MAD out here in Vancovuer so I want to resolve this asap!
Check all 4 of your drain tubes the bottom of the tubes (opposite end of where it attaches to sunroof assembly) has like a black plug on the end and that gets clogged which wont let the water run out. If you take off all 4 of the black ends and clean them it should help solve your problem. Also since you have them off you might want to blow some air through the tubes to get any gunk that might be sitting along the middle of the tubes.
i think my crx leaks where the brake lights mount to the body.. that's where my brothers 2000 hatch leaked untill we sealed it with some silicone.. check that location..
duneracer69
26
Jan 8, 2006 07:37 AM
