Blinker's stopped working
A friend and I are completely reconfiguring the interior of my 4th gen. Along the way somehow we lost turn signals. Is there a signal relay or something that could have blown in the process. Fuses are all good. All I did was relocate the window controls, heater controls, electric door locks, cruise and roof controls, and dimmer. None of which are having any problems. Marker lights come on fine too. Any help would be great, my arms are getting sore signaling.
I aggree with farrout
check the hazard button make sure the wires are pluged in all the way . the turn signals are wired up with the turn signal .... look at the fuses under the hood too one of does might be bad but , if your hazard lights are working fine then your fuses must be good
check your hazard switch. Make sure it isnt pushed in halfway. If the hazard switch is messed up in any way your blinkers will not work properly!
maybe/probably? it might have to be plugged in to complete the complex circuit of a turn signal, heh. on a side note, i've heard this problem quite a bit w/ 4th gens. wierd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">did you plug it back in? after you unplugged it</TD></TR></TABLE>
Yup found my hazard switch laying around plugged it in and presto i had blinkers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">you got hazards?</TD></TR></TABLE>
did, i dont have one wire in the car currently
egboy94
Feb 26, 2011 05:52 AM
BrayzieEF9
20
Feb 8, 2010 06:08 PM
EGTeK
Mar 26, 2003 10:52 AM
