My brake lights are stuck on?
Old Apr 3, 2003 | 09:12 PM
KEVlN's Avatar
New User
Default My brake lights are stuck on?
I got home from work tonight, and shut my car off, and as I got out of my car I noticed that my brake lights were on. Any ideas? I disconnected my battery for now.
-kev
Old Apr 3, 2003 | 09:26 PM
BMacls's Avatar
Default Re: My brake lights are stuck on? (B8TeenRex)
thats a hard one you can check to see it the bolt on the brake arm that pushes on the sensor is there or check the sensor to see if that the problem or its unpluged. check all the bulbs to see if they are good to
[Modified by SI_CRX_AUTOX, 10:27 PM 4/3/2003]
Old Apr 3, 2003 | 09:28 PM
KEVlN's Avatar
New User
Default Re: My brake lights are stuck on? (SI_CRX_AUTOX)
Ok, will check that. A friend told me that there is a brake switch that I can check. Where would this be located?
Old Apr 3, 2003 | 09:53 PM
Trinity's Avatar
i believe its right behind the brake pedal
Old Apr 3, 2003 | 11:37 PM
Crxer's Avatar
yup there should be a little switch behind the brake pedal, it pushes in when you press the brake so that your brake light will turn on. it may have been knocked out of place so check there first.
Old Apr 4, 2003 | 01:44 AM
guttedEF's Avatar
Default Re: My brake lights are stuck on? (Crxer)
It's actually pushing it while you're not touching the brakes. It releases the switch when you press the pedal.
But yeh, it's right behind the brake pedal, the actual lever part, not the foot pad. Get under there and push the pedal with your hand, you'll see it. Good luck, hope this fixes your problem. My brake lights don't work at all, only the running lights. I've tried everything..
Old Apr 4, 2003 | 04:26 AM
KEVlN's Avatar
New User
Default Re: My brake lights are stuck on? (guttedEF)
Thanks everyone and thanks Megan. I didn't want to feel like a jack *** asking you, but oh well look at me. Thanks for the title too. As soon as class is over I will go and try to fix the problem.
Old Apr 4, 2003 | 05:14 AM
Trinity's Avatar
i know its hard having to come to a girl about a car question. lol
Old Apr 4, 2003 | 07:15 AM
KEVlN's Avatar
New User
Default Re: My brake lights are stuck on? (Trinity)
LOL. Well you know your SH*T. Thanks again. The plastic piece that holds the switch in broke off. Has anyone rigged something up before? Any ideas on what I can do. I will probably just rig up a bolt in the place of the piece that broke off. Anyone know what size I will need?
Old Apr 4, 2003 | 07:39 AM
WuShu's Avatar
New User
Old Apr 4, 2003 | 07:42 AM
KEVlN's Avatar
New User
Default Re: My brake lights are stuck on? (HondaCRX)
Thanks.
Old Jul 5, 2003 | 10:04 PM
Stupid Ass's Avatar
Default Re: My brake lights are stuck on? (KEVlN)
Ok. I will try adjusting it tomorrow... I just had the same problem today.
Old Jul 6, 2003 | 12:09 AM
IMD's Avatar
IMD
Default Re: My brake lights are stuck on? (MooreVTEC)
Flat plastic golf shoes spikes work well, just have to get the right screw size. I just replaced mine a couple of months back. Also used the same thing on the clutch-ignition interlock switch a year ago. Hope that helps.
Old Jul 6, 2003 | 12:54 AM
jc836's Avatar
Did you say you need parts? I have the complete pedal assembly from a 90 HF sitting here. Drop me an e-mail if interested. On-topic: All hardware is metric and much of it is available from the dealer still.
TomCurllyFry
Mar 25, 2013 09:29 PM
asocallocal
Aug 29, 2010 07:00 PM
804tuned
Jan 14, 2010 07:50 PM
gsrsuperman
13
Jul 21, 2008 10:20 AM
musclehead954
Feb 27, 2008 10:28 AM
