Skunk2 stage2 And Toda Spec B's!! Help!
Old Apr 3, 2003 | 08:15 PM
hYpE-R-29's Avatar
Default Skunk2 stage2 And Toda Spec B's!! Help!
I know we have a wide variety of opinions about these 2 camshafts, but I wanted to know which one will make more power out in the long run, I am in the market for either or.
My set-up as follows:
Skunk2 camgears
JDM 4-1 header
Apexi N1 exhaust
Aem POwer pulley
V-AFC
AEM CAI
**I will be also getting a hondata system soon**
any advice
Old Apr 3, 2003 | 08:38 PM
seanb18c1's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (hYpE-R-29)
Those cams NEED compression kid. Stock 10.6 ITR static compression won't take full advantage of the cams.
Pistons and hondata should be next on your shopping list.
Old Apr 3, 2003 | 09:13 PM
hYpE-R-29's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (seanb18c1)
gracias any other suggestions?
Old Apr 3, 2003 | 09:33 PM
Blade's Avatar
New User
Peak power will be about the same, but Toda B's will have much better midrange and torque. Toda B
Old Apr 4, 2003 | 01:48 AM
Shark Tank's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (Blade)
actually peak will go to the skunk stage 2 cams while midrange and torque will go to the b's.
Old Apr 4, 2003 | 06:15 AM
TheOne's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (Shark Tank)
what compression would you use to match those cams. also, what compression could/should you run with stage 3 cams? I have hondata and injectors, but I still wonder how high of compression I can run with 93 octane.
p.s. I am thinking of selling my turbo kit and associated parts for an all motor set up, I already have an ITR tranny and want to run jun stage 3 cams with what compression, I dunno.
Old Apr 4, 2003 | 08:14 AM
Shark Tank's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (TheOne)
with toda b/c or jun 3 cams, you can run 12.5-13:1 compression with 93 octane only and good tuning since you have the hondata. so thats a pretty high compression street setup. remember bigger cams reduce compression, and need more compression to run appropriately. i would not build anything less than 12:1 with those cams
Old Apr 4, 2003 | 10:22 AM
TheOne's Avatar
that is what I was looking for, I want to go with 12.5:1 pistons. how do the cams reduce the compression though?
Old Apr 4, 2003 | 10:55 AM
rodrez.'s Avatar
I agree. I drove my friends JDM ITR hatch to get dyno'd one day, funnest trip ever. Toda B's and bolt ons with a super light flywheel was a lot of fun. They ended up dynoing 206hp, 138tq. When you get on it, the transition from low to high cam is so smooth that you don't feel a kick or a change in sound, it just keeps pulling. Incredible midrange on that motor, even with the stock compression.
Old Apr 4, 2003 | 11:59 AM
Shark Tank's Avatar
cams reduce compression in that a bigger lobe lowers compression values. its called ABDE specs of the cam. do some research on H-T or the net and you can read for yourself. its been covered many times
Old Apr 4, 2003 | 12:09 PM
skafia's Avatar
25 Year Member
What about a JDM ITR Block that yields 11:1 compression, would that utilize the Skunk2 II's?
Old Apr 4, 2003 | 02:13 PM
SoCal ITR's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (skafia)
I think it's the pistons that yeild the 11:1 on the JDM motor, but I still think that's too low, personally.
Old Apr 4, 2003 | 02:22 PM
(__________)'s Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (SoCal ITR)
CTR pistons are the way to go
Old Apr 4, 2003 | 02:35 PM
MK Ultra's Avatar
There are two types of Compression Ratios. Static and Dynamic.
Static compression is just a mathematic ratio of cylinder volume to combustion chamber volume. For example, an engine with 500 cc per cylinder and 50 cc per combustion chamber has a static compression ratio of 10:1. This is what people are referring to when they talk about compression ratios.
Dynamic compression is how much your motor actually compresses the air inside the cylinders. Dynamic compression is based on how much air is actually in the cylinder during the compression stroke. To simplify things it will suffice to say that running a lot of overlap on the cams causes some loss of dynamic compression.
[Modified by MK Ultra, 5:36 PM 4/4/2003]
Old Apr 4, 2003 | 03:04 PM
hYpE-R-29's Avatar
these are some great info guys keep them coming
Old Apr 4, 2003 | 03:27 PM
Shark Tank's Avatar
mk is explaining it very well...he summed up the articles i told you to search for in about 2 paragraphs. basically if you want my true opinion, if you want to run toda b/c, skunk 2 stg 2/3 or jun 3 cams, your STATIC COMPRESSION should be no less than 12:1 to take full advantage of these cams. a few very respectable tuners recommend at least 11.6:1 compression for these types of cams
Old Apr 5, 2003 | 11:18 AM
seanb18c1's Avatar
More info:
http://www.team-integra.net/forum/di...PagePosition=1
Old Apr 5, 2003 | 11:35 AM
gsr-2nr's Avatar
todas will give u much bigger power gains over skunk2
Old Apr 5, 2003 | 11:54 AM
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (gsr-2nr)
That is a very vague answer it is all about tuning
Check the cam specs out on each cam here:
http://www.allmotorhonda.com/techpages/camspecs.htm
Old Apr 5, 2003 | 12:27 PM
Shark Tank's Avatar
Default Re: Skunk2 stage2 And Toda Spec B's!! Help! (steves98itr247)
one needs to look at the lift on all 3 lobes. not just the vtec lobe. vtec lobe lift only tells you peak power and not how much low and midrange power
JDM_7
Jun 26, 2010 08:41 AM
cyber gook
23
Apr 10, 2008 05:38 AM
EF_LSVtec
30
Oct 1, 2003 09:22 PM
Beave0101
Jan 2, 2003 12:43 PM
vtecjj
Dec 15, 2002 10:22 PM
