How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!!
Old Apr 3, 2003 | 07:47 PM
integraautox's Avatar
Default How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!!
Ok I am half way through installing my new tranny/clutch. I am in the process of attacing the clutch to the flywheel. I already torqued my flywheel bolts to 85lbs I need to know how hard to torque down the clutch to flywheel. I was under the impression of just as hard as I can with a nrmal rachet. Thanks a lot
Old Apr 3, 2003 | 07:50 PM
garados's Avatar
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (integraautox)
umm, I believe it's 35 pounds, but it could be 50, but I'm pretty sure it's 35 pounds
Old Apr 3, 2003 | 07:53 PM
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (garados)
so is that about hand tight with the rachet just not using a torque bar or anything
Old Apr 3, 2003 | 07:55 PM
garados's Avatar
Nope, no hard core tools needed. On mine, I had a little pipe around an allan wrench and just tighened it until it felt like 35 pounds
Old Apr 3, 2003 | 09:03 PM
ITR#132's Avatar
Those bolts are too small to trq to 35ftlbs., You will strip threads or snap the bolts.
Old Apr 3, 2003 | 09:09 PM
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (ITR#132)
Hey I tightened the bolts down to 35lbs. I read on another site thats the proper pressure. Thanks for you help. All I have to do now is slap the tranny on the car and tighten the bolts will have it down by tommorow night.
Old Apr 4, 2003 | 04:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
okay lots of conflicting info here. Go buy a Hayne's manual for about $12, it will list the specs you need to know. Stuff like this you want to do it right. We tightened the bolts on my friend's clutch to proper specs, tightening in steps in a star pattern around the pressure plate. I would look it up for you but I don't have my manuals with me.
Old Apr 4, 2003 | 05:53 AM
BSQ's Avatar
BSQ
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (PatrickGSR94)
I installed a new clutch a few weeks ago and I seem to remember that the Helms manual said 19 ft./lbs. I checked c-speed and they stated 24 ft./lbs. ( http://www.c-speedracing.com/howto/b...ch/clutch2.php ).
Old Apr 4, 2003 | 06:59 AM
KiLLa CaM 06's Avatar
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (BSQ)
tighten untill the whole clutch is starting to turn.
Old Apr 4, 2003 | 07:51 AM
BSQ's Avatar
BSQ
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (olskodumie)
If you do this, then you will not get the bolts tight enough . I used a tool which holds the crank pulley when tightening my PP bolts. If I wouldn't have done this, then my bolts would have not been tight enough.
Old Apr 4, 2003 | 07:55 AM
DevinW's Avatar
My helms also says 19 ft/lbs.
Old Apr 4, 2003 | 08:36 AM
PupaScoopa's Avatar
Default Re: How Hard To Tighten The Clutch To Flywheel Bolts ASAP!!!!!! (DevinW)
A tip for you guys when tightening the flywheel bolts or the clutch pressure plate bolts...
To hold the flywheel, the manual shows a special tool used to lock the flywheel.
If you don't have the tool, just have someone with a ratchet and cheater bar (pipe) hold the crank bolt while you torque
vaypourus
Nov 9, 2006 06:26 PM
flip1199
Nov 7, 2005 11:07 AM
lsvtec101
Jun 7, 2004 09:52 AM
jdmCivic925
Mar 13, 2004 07:23 AM
4doorH22
Mar 12, 2002 06:31 PM
