which oil filter?
i was wondering what oil filter i should use for a zc motor. just got the car so i dont really know anything about the motor. and if you guys can provide me with how much oil goes into the motor, that would be helpful.
Use one for an 88 - 91 Civic. I believe they are all the same. Get one with a good anti - drainback valve like Wix or Bosch. Don't get Fram. Anyway, it takes a little under 4 quarts of oil. I believei it is the same specification as listed on the stock air filter box (for a USDM car), but check the dipstick just to be sure.
Fram has/had cardboard endcaps and a cheasy anti drainback valve that would let oil drain back out of the filter. Plus the filter medium was smaller than anyone elses. Look here for a comparison on different brands. http://people.msoe.edu/~yoderw....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx »</TD></TR><TR><TD CLASS="quote">all hondas use the same filter,if you have an advanced autoparts they sell k&n oilfilters$7.00 thats what i use
Not true. The new SOHC engines in the 7th gen's use a different, smaller filter. Fram PH7317. But yes, almost all Honda's use the same filter. I know one or two more that are different too.
</TD></TR></TABLE>Not true. The new SOHC engines in the 7th gen's use a different, smaller filter. Fram PH7317. But yes, almost all Honda's use the same filter. I know one or two more that are different too.
i use honda oem filters and buy a set of 10 from http://www.ahmotor.com/. with the crush washers its usually under $60 shipped!
Read that link above to see what's wrong with Fram, I still use them too but I've been trying to find something else to switch to. When you read that site it seems that every filter you see in a parts store is made by Fram anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">OEM
that's all you need and it's cheap and honda makes it for a reason, to go with honda motors
</TD></TR></TABLE>that's all you need and it's cheap and honda makes it for a reason, to go with honda motors
ITR_1211
Sep 17, 2001 03:47 PM
