did i damage my tranny? - drove with low oil
Old Apr 3, 2003 | 06:40 PM
serious's Avatar
Default did i damage my tranny? - drove with low oil
i drove several miles with my tranny whining from, i later found out, low oil. i was probably a quart short (or close to it). it was whining very loud, loud enough to hear it going 50 with the window down. i oil lose probably resulted from either an axle which didn't seat or a damaged axle oil seal. my question is, what are the chances i damaged a transmission bearing?
[Modified by serious, 10:41 PM 4/3/2003]
Old Apr 3, 2003 | 06:50 PM
MrTodd's Avatar
Default Re: did i damage my tranny? - drove with low oil (serious)
You have two options:
A. Take it apart and inspect everything yourself (or have a shop do it).
B. Refill the tranny with 'Honda MTF' (get it at your local dealer), make sure there are no leaks, then drive it and see if it makes any noise.
Considering you do option 'B', if there is anything wrong with the tranny, you'll definitely feel/hear it.
civbeater90's Avatar
well how does it sound after oiling it?do you here the sychros grinding?
Old Apr 4, 2003 | 07:11 AM
slowassgsxr750's Avatar
Default Re: did i damage my tranny? - drove with low oil (civbeater90)
i drove two hours without fluid,just added fluid and it ran fine
Old Apr 4, 2003 | 07:30 AM
DJ_SaNdOz's Avatar
Default Re: did i damage my tranny? - drove with low oil (singleslamrex)
mines been leaking for months & it still works fine- i need the bearings replaced, but it shifts fine. i definatly wouldn't reccomend it tho.
Kid-jdm-teggy
Transmission & Drivetrain
Sep 10, 2013 08:41 PM
89 ed6 FTW!
Oct 22, 2010 07:09 AM
HondaHeddie
Sep 29, 2006 07:40 PM
revv
Feb 22, 2004 05:45 PM
serious
Apr 3, 2003 06:46 PM
