h22 hybrid guys...What did you do about your clutch line?
Old Apr 3, 2003 | 05:35 PM
Jonathan_ED3's Avatar
Default h22 hybrid guys...What did you do about your clutch line?
Pics would be a MAJOR plus.
I've seen most people run the stock Civic hardline to the h22 slave cylinder.
Now my question is...when you got your engine, what originally ran to the slave cylinder?
On my engine, the slave cylinder has a hardline already in it, that runs up above the tranny, near where the shift calbes mount, and from there, is a banjo fitting on a rubber line that then went to the prelude hardline.
Is anybody elses tranny setup like this?
I've been told to run it to the slave cylinder directly.....but doing that, i'd have to block off TWO hydraulic lines. It just doesn't seem like the right way to do it...
Can anybody show me some close up pics of the top of the tranny case/slave cylinder area?
Poison and I are trying to get this figured out...but in the meantime I can't stand waiting for him to get his pics up. I've been looking at Fastwanabe's pics, and his is run straight to the slave cylinder, and from what I can tell, he doesn't have the other lines that I'm seeing. I'm wayyy confused.
Sorry for the long post. TIA.
Old Apr 3, 2003 | 05:40 PM
hondaeg5's Avatar
Default Re: h22 hybrid guys...What did you do about your clutch line? (hot_EG)
im looking at my swap and i have that hardline that goes to a banjo fitting. im going to try running the civic hardline straight to the slave. sorry dont have any pics.
Old Apr 3, 2003 | 05:45 PM
cccya's Avatar
Default Re: h22 hybrid guys...What did you do about your clutch line? (hondaeg5)
mabeye this will help....
Old Apr 3, 2003 | 05:48 PM
hondaeg5's Avatar
Default Re: h22 hybrid guys...What did you do about your clutch line? (cccya)
drooooool. what car is that in?
EDIT:
just found out. from the banjo fitting on the original setup,there is a line that goes to a clutch dampener(sp?) then from there its a hard line to the clutch master.
[Modified by hondaeg5, 9:54 PM 4/3/2003]
Old Apr 3, 2003 | 05:53 PM
Timmayeg's Avatar
New User
i dont have any pics but i just used the stock h22a line and hooked it into my stock CX line(the rubber side) , it will go from hard to a "mount" then to a rubber line, i rebent the h22a line over to where the "rubber" line on the car is and hooked it up there. if that makes sense? dont ask poison he doesnt know ****, LOL. i had to tell him how to do 1/2 his swap
Old Apr 3, 2003 | 05:55 PM
poison's Avatar
ok Jon, you're on
I'm looking for my pics now on We-todd. I'll post 'em up if i have 'em in we-todd right now, if i don't have any, I'm posting tonight indefinitely.
Old Apr 3, 2003 | 06:01 PM
poison's Avatar
Default Re: h22 hybrid guys...What did you do about your clutch line? (Timmay)
HA!! talkin **** again
you're wrong snurl, you're supposed to use the civic bubber line on the lude slave cylinder.
Old Apr 3, 2003 | 06:06 PM
Timmayeg's Avatar
New User
Default Re: h22 hybrid guys...What did you do about your clutch line? (poison)
i dont know if mine came with a "bubber" line? i hooked the stock civic rubber line to the long line going into the h22a S/C. god i wish i had some pics of it to show you want im trying to say
Old Apr 3, 2003 | 06:09 PM
poison's Avatar
Mine didn't either. The line Jon got I have no idea where it came from. Looks like it's a brake line.
But I'm taking a pic once I get off work of this thing.
Old Apr 3, 2003 | 06:13 PM
Timmayeg's Avatar
New User
you mean rubber not bubber right??? thats why i said mine didnt come with a bubber line it had a rubber one though, LOL *** clown
Old Apr 3, 2003 | 06:15 PM
poison's Avatar
omg to me ROFL.
Old Apr 3, 2003 | 06:16 PM
so the thing on top of the tranny that has a banjo fitting attached to a rubber line is the clutch damper?
Is that what I'm reading?
Anybody know what L'Orange's civic hardline is attached to? I noticed his slave cylinder hardline goes up over the tranny like mine does.
Old Apr 3, 2003 | 06:18 PM
this is what I've been told to do, but if you do this.....what are you going to do with 1) the rubber line, and 2) the line that goes between the banjo fitting and the slave cylinder?
Wouldn't that just bypass the whole stock assembly? Why would one want to do this? I mean obviously, it's there for a reason
Old Apr 3, 2003 | 06:25 PM
hondaeg5's Avatar
sorry should have explained it better. from the clutch master there is a hard line,that goes to a dampener(sp?) or resiouvr(sp?)(actually i have no clue what it is! lol) then from that there is a rubber line that attaches to the banjo fitting. i know what you saying about bypassing what was originally there. my friend and i are arguing about this right now because he doesnt have it and he says it works fine.
[Modified by hondaeg5, 10:27 PM 4/3/2003]
Old Apr 3, 2003 | 06:30 PM
just to clear things up...i don't have the stock civic rubber line...so that might pose some of my problem.
all I have is the civic hardline....and the rubber line attached to a banjo fitting on top of the h22 tranny. To get it to work, I need this line lengthened, or a custom line to go between my civic hardline and the end of the h22 rubber line.
Old Apr 3, 2003 | 06:35 PM
hondaeg5's Avatar
i dont have a rubber line on my civic either. i really dont know exactly what poison or timmay are speaking of. i hope one of them posts pics.
Old Apr 3, 2003 | 06:37 PM
poison's Avatar
Ok, you won't need any of that on top of the tranny. Just simply connect the Civic hydraulic clutch line directly to the prelude slave cylinder using the Civic rubber line.
Old Apr 3, 2003 | 06:43 PM
hondaeg5's Avatar
i dont understand, is there supposed to be a rubber line on the civic?
Old Apr 3, 2003 | 06:46 PM
poison's Avatar
There is the factory civic hydraulic clutch line from the master cylinder. It goes to the side frame rail, then there is a rubber line fitted onto that.
To make it work with the Prelude Slave Cylinder, you remove all lines and such on the prelude tranny, and use the factory civic rubber hose and put that directly onto the prelude slave cylinder on the tranny...
make sense?
Old Apr 3, 2003 | 06:50 PM
hondaeg5's Avatar
just went to look at my car, ooooh yea,im a dick! on me. its all clear now. thanks alot!
Old Apr 3, 2003 | 07:20 PM
haha, problem is that i don't have a stock civic line!
But I guess I now know I need to get one.
So I just disregard all the stuff on the top of the tranny? What is this stuff anyway?
How exactly do I bypass it? I mean there's obviously fluid and crap flowing around in there
Old Apr 3, 2003 | 08:41 PM
fastwanabe's Avatar
hey HOT EG.. look at this pic, I ran the stock hard line right to the clutch thingy. Its not pretty but it works.
[Modified by fastwanabe, 6:13 AM 4/4/2003]
Old Apr 3, 2003 | 08:52 PM
Default Re: h22 hybrid guys...What did you do about your clutch line? (fastwanabe)
Awesome...I finally got a good look at this thing above the tranny, and it turns out I can unbolt it and bend the entire line out!
So I can get it pretty dang close to the stock civic hardline, which means I can use the stock Prelude rubber line with it
Thanks for the pic Fastwanabe!
Old Apr 3, 2003 | 09:15 PM
fastwanabe's Avatar
how the hell do I resize the pic?
Old Apr 3, 2003 | 09:23 PM
you gotta do it on whatever program you use to view pictures.
For instance, I use 'PM View'
There's always a feature that you can use to downsize/upsize.
For instance....I go to 'Transform'....and then 'Size'...and then I can do whatever percentage I want.
I usually do 50% of the original size for larger pics.
