zc swap code 14,7and 9
Old Apr 3, 2003 | 04:28 PM
daniel89civ's Avatar
Default zc swap code 14,7and 9
i finish my zc swap and iam getting code 14, 7 , and 9 how can i fix those codes
the search is disable ..........why
Old Apr 4, 2003 | 05:27 PM
Default Re: zc swap code 14,7and 9 (daniel89civ)
any 1
Old Apr 4, 2003 | 05:50 PM
USDM 4G VTEC's Avatar
k
Code 7 its TPS. if u did a ZC swap u should have inverted the yellow and grn cables off the TPS sensor bc the ZC reads backwards....
code 9 its CYL.. maybe u got the CYL sensor disconected or not conected properly to the ECU
code 14 IACV (EACV). its the lil cyl thingy behind trotle body that controls the amount of air that goes into manifold when engine its cold.... maybe u used the wrong plug...
[Modified by USDM 4G VTEC, 11:25 AM 4/6/2003]
Old Apr 5, 2003 | 04:17 PM
Default Re: zc swap code 14,7and 9 (USDM 4G VTEC)
whaT COLOR IS THE (EACV) plug green or white
Old Apr 5, 2003 | 06:59 PM
Ham'ed Hatch
Guest
Posts: n/a
actually the EACV controls how much air to add to the intake stream while idling. not only when it's cold.
and it's a GREEN plug.
Old Apr 5, 2003 | 10:32 PM
drjondurst's Avatar
k
Code 7 its TPS. if u did a ZC swap u should have inverted the red and grn cables off the TPS sensor bc the ZC reads backwards....
hold the **** up, is this true? I did a ZC swap and didnt mess with any of the TPS wiring and I'm getting a code 7 that I just cant get rid of. How come I've never seen/heard of this ANYWHERE before?
Old Apr 5, 2003 | 11:01 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: zc swap code 14,7and 9 (drjondurst)
lmfao! that's ****** hilarious dude
Old Apr 5, 2003 | 11:09 PM
drjondurst's Avatar
Default Re: zc swap code 14,7and 9 (Ham'ed Hatch)
lol those are the exact words that came outa my mouth when I read that you have to switch around the tps wiring. I've had my ZC in and running since last sunday and cant get rid of those code 7.. this better fix it.
Old Apr 6, 2003 | 07:23 AM
hold the **** up, is this true? ?
well let me explain this
when i asnwer the guy , i read he has a DX model... its DPFI... DPFI systems have a TPS that runs backwards..... that means i gotta invert the cables to make it work good....
heres a lil cut paste from my .DOC of info for my swaps... "The last modification is VERY important! You must reverse the green/white and yellow/white wires on the Throttle Position Sensor, because the DX’s turns backwards. "
i beleive if u have a Si u dont have to invert them,... but doesnt hurt to try.. bc my car was a STD.. i inverted them for my Z6 swap... and they were wrong ... iu i had to rewire back to normal and it worked fine.... **** crazy
Old Apr 6, 2003 | 10:02 AM
i was running a minime before look at the singnature my dx was already mpfi
Old Apr 6, 2003 | 10:43 AM
H.crx-si
Guest
Posts: n/a
hey daniel89civ in your sig is says that you ran a 15.9 quarter before the mini me and correct me if I'm wrong but are you also saying after the minime you still ran a 15.9?
Old Apr 6, 2003 | 11:56 AM
drjondurst's Avatar
Ahh I c.
Old Apr 6, 2003 | 05:36 PM
yes i ran 15.9 i could not get better with my minime it had alot of low end it spun tire first and second the minime was turqier than the d16a6 the d16a6 did not spun alot of tire
drewboy
May 16, 2005 05:24 AM
JapJunkie
Mar 22, 2004 11:05 AM
Pcart
Oct 17, 2002 05:59 AM
