Hitech exhaust
I was on their web site looking at the price lists and the Honda street header is $1000, the drag race one is $1300. I assume the drag header just has a silencer canister at the end of the collector, has slightly larger piping, what is the difference? Does anybody here have one? Do you run a drag header on the street? Is it better than TODA or Spoon? I saw that they made exhausts for Indy Cars and top race teams so these guys must be awesome.
this is an ongoing header debate from way back.
i think u can get some questions answered if you do a search cuz
ur questions have been answered before and more
damn i sound like a freakin mod
I nominate stick to be a pseudo-mod....
Lip and Tony the Tiger are the Hi Tech users here so they can tell you lots of firsthand experience...all positive. I haven't seen John around for awhile.
As I said to John: it should be sitting in the MOMA or something as a sculpture. He laughed and said he would prefer you put it on the car....
https://honda-tech.com/zerothread?id=28638
https://honda-tech.com/zerothread?id=42814
Very nice header. I still can't get over the fact Lip ran almost the same time as sgt with a broken axle...amazing....
cheers
cheers
You will require a custom 2.5" catalytic converter with the Hytech setup. I'm not sure if it (the header) has bungs for both 02 sensors, but it is likely you will need extensions to the wires for the 02 sensors if they are there. You will also need a custom B-pipe.
.....I'm not sure if it (the header) has bungs for both 02 sensors, ...
...but it is likely you will need extensions to the wires for the 02 sensors if they are there...
...You will also need a custom B-pipe.
bit longer than stock, so you will need to modify the B-pipe of your exhaust system.Austin
umair
May 28, 2009 03:09 PM
D3U1LT
May 11, 2005 08:49 AM
sircrxracer
Jan 25, 2005 03:48 AM
