del sol seats in EF
Old Apr 3, 2003 | 09:23 AM
Rob!'s Avatar
Default del sol seats in EF
hey guys im trading a friend of mine my stock HF seats for some del sol seats. someone hit him and he said i can take what i want so im gonna grab the seats and the wheels. i need to see some pics of how you made the mounts for these because i havnt seen it done.
Rob
Old Apr 3, 2003 | 11:33 AM
quis23's Avatar
Default Re: del sol seats in EF (RaceFacer)
the point on the front right lines right up , you're gonna have to make some customs brackets and bolt them up or weld them lik ei did to make the other 3 fit.
some more info: http://www.thedropshop.tv/seats.html
[Modified by quis23, 8:35 PM 4/3/2003]
Old Apr 3, 2003 | 11:48 AM
ElementMotor's Avatar
I don't have pics of my brackets, but when I had them installed, my friend used my stock rails from my 90 Si hb. It was a lot of work welding and **** but it worked awesome, looked stock and they still slid back and forth and all that good stuff.......It took about 2 hrs per seat to do it.....worth it though
Old Apr 3, 2003 | 02:07 PM
bfrank81's Avatar
Default Re: del sol seats in EF (quis23)
NICE!!
Old Apr 3, 2003 | 04:17 PM
boostedb16a3's Avatar
Default Re: del sol seats in EF (bfrank81)
question. i just bought a 91 hatch back dx, and i have 92 gsr leather interior.The interior that has the two part seat belt. Do you know which rails i should use? Im trying to use the dx rails but its not working out too well. let me know if you have any info.
Old Apr 4, 2003 | 10:11 PM
RapeV-8's Avatar
nice i try to make it work but it didnt!!! i still got it in my garage dammit
Old Apr 5, 2003 | 07:08 PM
MiChangCRX04's Avatar
I have 97 Del Sol seats in my 89 CRX si. My dad an i fabricated the mounts an welded them in so that the seat simple bolts back in like the seats were oem. I'll barrow my friends digital camera and take some pics to post.
89 CRX si B16a w/ the wrong shift linkage (previous owner a dumbass)
Old Apr 5, 2003 | 11:55 PM
Cvic90's Avatar
I don't have any pics, but a tip. The inner front mount on both seats, drill out the rivets and swap from one to the other. bolt the outer front in the car still atached to the seat and weld the mounts back on the opposite. worked great for me, positioned them well too. then drill out the outer rear and weld it back on to fit. the flat inner rear is up to you. i haven't changed it yet.
Old Apr 6, 2003 | 08:05 AM
brent_G's Avatar
Default Re: del sol seats in EF (Cvic90)
yup welding is about the best way...you can drill a hole through the rear left side on the drivers side through the floor and put a bolt there to hold it in place...nut on the exterior. And same for passager except on the right side...just drill a hole through the floor and nut and bolt will work. One of the fronts lines up. Front right side for the drivers side. The the other side is goin to be needing some welding. thats how it was in my 88si.
Old Apr 7, 2003 | 04:54 AM
Rob!'s Avatar
Default Re: del sol seats in EF (screamincivik)
is there any way to mount the crx brackets to the del sol seats?
Old Apr 12, 2003 | 10:04 PM
Full-Race Henry's Avatar
Default Re: del sol seats in EF (b16hf)
Thats what I heard you have to do to make the del sols to fit in the CRX
Old Apr 13, 2003 | 10:28 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hf &raquo;</TD></TR><TR><TD CLASS="quote">is there any way to mount the crx brackets to the del sol seats?</TD></TR></TABLE>
i figured, this would be the easy way to do it! too bad i didn't try it, when i had the del sol seats!
Old Apr 17, 2003 | 01:32 PM
brent_G's Avatar
Default Re: del sol seats in EF (smokey2.0)
instead of welding i made a bracket to fit for my crx. ON the front drivers side the right side lines up. So i bolted that down. On the left side its about 2 inches from the orignal hole. So i cut a strip of hard steel painted it black. Drilled 2 holes in it. one on each end. I mounted the one side to the del sol slider and the other side was lined up pretty well with the hole. So there is a strip of metal about 2 inches long connecting the hole to the seat. I used lock washers to make sure it wouldtn move. Then on the back i drilled a hole through the floor and put a bolt and nut and washer on for that. And the other side sits there. Its sturdy as can be and ill be able to take them out sometime and sell em if i want.
Old Apr 17, 2003 | 01:41 PM
SpeedMonkeyRacing's Avatar
what about bolt the stock mount onto the del sol seats? like drill holes for the bolts and mount them?
Jeff-
Old Apr 17, 2003 | 09:09 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamincivik &raquo;</TD></TR><TR><TD CLASS="quote">instead of welding i made a bracket to fit for my crx. ON the front drivers side the right side lines up. So i bolted that down. On the left side its about 2 inches from the orignal hole. So i cut a strip of hard steel painted it black. Drilled 2 holes in it. one on each end. I mounted the one side to the del sol slider and the other side was lined up pretty well with the hole. So there is a strip of metal about 2 inches long connecting the hole to the seat. I used lock washers to make sure it wouldtn move. Then on the back i drilled a hole through the floor and put a bolt and nut and washer on for that. And the other side sits there. Its sturdy as can be and ill be able to take them out sometime and sell em if i want. </TD></TR></TABLE>
post a picture!
keenspeed94
Nov 4, 2006 02:43 PM
Japan
Aug 11, 2006 11:20 AM
bigBOI_92DA9
Jul 21, 2005 04:38 PM
shoebox
Nov 14, 2003 12:30 PM
W0oT
Aug 24, 2001 10:34 AM
