Setting B16a Ignition Timing in a CRX
Old Apr 3, 2003 | 08:37 AM
7rrivera7's Avatar
Default Setting B16a Ignition Timing in a CRX
I need to set the ECU to 'diag mode' so I can set the timing. Anyone one been able to 'jump' pins somewhere to do this?
Old Apr 3, 2003 | 10:24 AM
V3locity's Avatar
Default Re: Setting B16a Ignition Timing in a CRX (7rrivera7)
if it's an 88, the plug you need to jump is over near the windshield washer resivoir and coolant overflow. I think it has a yellow rubber cover. Just short those wires out.
Old Apr 3, 2003 | 11:43 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Setting B16a Ignition Timing in a CRX (illdezignzls)
why do you need to do this? cant you just shoot the timming gun?
Blaze
Old Apr 7, 2003 | 05:36 AM
7rrivera7's Avatar
When I short the wires, I don't see a change in the idle. I'm assuming the idle should go down to ~750 rpms and a check engine light should come on right? Does the wiring for this connector stay 'enabled' when you swap in a B16 engine into a CRX Si?
7rrivera7
Mar 27, 2014 03:07 PM
Blueallie
Dec 11, 2004 09:16 PM
mikenme
Apr 7, 2004 05:01 PM
raene
Apr 12, 2002 07:18 AM
non-VTEC
Jan 27, 2002 12:15 PM
