How to get rear motormount bolt loose?!?!?!
Ok this is the second time I have posted. No one has helped me out and the search function is still down. I have a Hasport Mount kit and need help getting the rear motor mount off. The instructions on the kit don't help a bit they just give you a broad "how to install." No specific details. It is a 14mm bolt behind the mount. Oh ya its on a 91 EF Civic. I tried one of thoose wobbly socket extentions and it would barely fit. Do I have to take the rear cross member off or something.
Some one please help and pictures would really help to.
You can get it out with it in, it gets alittle tricky cause of the room to work with. I used a couple extension pieces and kind of angled it the right way. Just keep trying.
[Modified by 90blackcrx, 1:33 PM 4/3/2003]
That mount sucks! Place the socket on the bolt and then carefully "shove" a long extension straight down. The extension needs to be right against the firewall for it to fit. I cant remember if i had to remove any stuff that is bolted to the firewall or not but it does work. I didnt think it would when someone described it to me but the extension really did fit.
