What trannys does the ITR LSD drop into?
Old Apr 3, 2003 | 07:16 AM
Screaming Vtec's Avatar
Default What trannys does the ITR LSD drop into?
As above..
Ive got a brand new ITR LSD and would like to find out which trannys it can e installed in..
Also are there any other addition parts needed?
Thanks
Old Apr 3, 2003 | 07:32 AM
acura_typer's Avatar
Banned
Default Re: What trannys does the ITR LSD drop into? (Screaming Vtec)
ITR
CTR
94+ GSR
Old Apr 3, 2003 | 07:58 AM
Default Re: What trannys does the ITR LSD drop into? (acura_typer)
Thnks for that..
Does it fit any Civic Trannys at all?..
In the GSR does it drop straight in or are other parts needed?
Old Apr 3, 2003 | 08:25 AM
CHEETAH's Avatar
it'll drop into any 4.4 final drive b-series tranny, regardless of year or whether its cable or hydraulic... for any of those trannys that is not an ITR, GSR or CTR then you need the ring gear from a GSR or ITR as well.
greg
Old Apr 5, 2003 | 06:36 AM
PupaScoopa's Avatar
Default Re: What trannys does the ITR LSD drop into? (CHEETAH)
You'll also need the 80mm thrust shims to clearance it properly.
Old Apr 5, 2003 | 06:45 AM
IS3Fifty's Avatar
Default Re: What trannys does the ITR LSD drop into? (PupaScoopa)
well considering the ITR and CTR come with it.. I dont think you have to drop them in. you can put it in a GSR, LS, Si. Basically any B series motor. I do not know if they will fit H series.
Old Apr 5, 2003 | 03:32 PM
lowcivex's Avatar
i dropped one in a gsr tranny
no problems and no shims!!!!
HondaTeKnology
Mar 20, 2008 11:40 AM
CWESTINAP1
18
Jun 23, 2004 05:11 AM
Micro
Nov 10, 2003 03:18 PM
