car sputters after first cranking up. help!
Old Apr 3, 2003 | 05:41 AM
Disco Monkey's Avatar
Default car sputters after first cranking up. help!
my car sputters after i crank it up. it doesn't do it right away though. i crank the car and let it idle for a little bit then it will start sputtering and act like its about to die, then the idle will go back up. sometimes i start driving it after i crank it up and the car will cut power and start sputtering and then it will stop sputtering and then runs fine. but it only happens after i first crank it up. it does it just about every time i crank it up no matter how long it has been sitting. i have changed my cap, rotor, coil, plug wires, plugs and it still does it. i dont get any check engine lights from it either. any other ideas what may be wrong?
02 sensor maybe? map sennsor?
need help its driving me nuts.
thanks
Old Apr 3, 2003 | 05:43 AM
Chubz's Avatar
Default Re: car sputters after first cranking up. help! (Disco Monkey)
check the voltage on the tps sensor, I had the same problem i believe at closed throttle voltage shoud read .45 and at wot 4.5
Old Apr 3, 2003 | 05:50 AM
who00knows's Avatar
Default Re: car sputters after first cranking up. help! (Freakzilla)
Do you have an aftermarket manifold?
Old Apr 3, 2003 | 09:17 AM
Default Re: car sputters after first cranking up. help! (who00knows)
i have stock manifold.
my throttle voltage according to the vafc is:
closed .385-.390 (it fluctuates)
open 4.550-4.560 (fluctuates).
Old Apr 3, 2003 | 06:39 PM
any more help?
Old Apr 4, 2003 | 06:33 AM
vtec.dc2's Avatar
when you first place the key in ignition, turn it where all the lights are on - you should wait a second or 2 before cranking. you should crank it as soon as you place the key in ignition.
Old Apr 4, 2003 | 06:38 AM
Louie's Avatar
What would Chente do?
Default Re: car sputters after first cranking up. help! (vtec.dc2)
Check your v-afc connections. Re-solder if necessary. That's what it was for me anyway.
Old Apr 4, 2003 | 07:05 AM
ZygSpeed's Avatar
Default Re: car sputters after first cranking up. help! (Louie)
I've got something similar in my Rex, I'm thinking a leaky injector in my case.
Mostly because it stumbles when started, and then clears up in a few seconds or so.
No mods on this car. Ed
Old Apr 4, 2003 | 07:12 AM
i always prime the fuel pump. very rarely do i just put the key in and start it up right away.
and i had this problem before i put the vafc in, so i dont think that is the problem.
someone suggested that it might be my ignitor.
Preludelearner
Mar 26, 2015 07:54 PM
Bonestock98GS
Jul 25, 2011 02:55 PM
ShadowWorkssimc
Sep 15, 2009 09:01 PM
B-serious
Mar 8, 2006 10:02 PM
