fuel pump relay
when you turn the ignition to the "on" position, you should here a humming sound coming from the trunk. it helps if your rear seat is down. you should here the noise everytime you turn the key to "on." if at any time you turn it to on, and you don't here the humming, which is the sound of the fuel pump building pressure, than most likely your relay is going bad. Of course, it could be the pump as well, but those do not go out as often.
400whp
Apr 28, 2011 02:20 PM
ekb16
13
Jul 5, 2005 06:30 PM
