JDM Type R cams VS. USDM Type R cams?
Old Apr 2, 2003 | 08:33 PM
spoonfed95's Avatar
Default JDM Type R cams VS. USDM Type R cams?
I see alot of people like to switch to JDM Type R cams, Why is this? Are they Different? Do they make more power? What? I am curious.
[Modified by spoonfed95, 5:47 AM 4/3/2003]
Old Apr 2, 2003 | 08:44 PM
spoonfed95's Avatar
Default Re: JDM Type R cams VS. USDM Type R cams? (spoonfed95)
What nobody know?
Old Apr 3, 2003 | 12:02 AM
96dc2's Avatar
3 degrees more duration is insignificant. Just get the cheapest of the two you can find.
Old Apr 3, 2003 | 12:05 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: JDM Type R cams VS. USDM Type R cams? (96dc2)
00-01 specs are diff on the intake side then the latter...00-01 spec are like the ctr intake cam...all exhaust cams are the same
Old Apr 3, 2003 | 12:11 AM
Reid's Avatar
Global Moderator
Default Re: JDM Type R cams VS. USDM Type R cams? (CiRcUiTsi)
All Type R exhaust cams are the same.
96-97 JDM/97-99 USDM (and CDM) ITR = same intake cam
98+ JDM/CTR = same intake cam (3 degrees more duration than above cams)
00-01 USDM ITR = similar to 98+ JDM/CTR intake cam
Old Apr 3, 2003 | 10:48 AM
spoonfed95's Avatar
Default Re: JDM Type R cams VS. USDM Type R cams? (Reid)
Well that answers my ? thanks Reid.
GsrSleeper18
Mar 21, 2005 01:38 PM
^R@m!r0_(M)
Jan 28, 2004 05:16 AM
clemens
Sep 4, 2002 09:00 PM
CivicRacer_ITC
Jun 3, 2002 12:58 PM
AztecB17
Apr 3, 2002 09:49 PM
