ok just confirm this for me...
Old Apr 2, 2003 | 07:34 PM
pdiggitydogg's Avatar
Default ok just confirm this for me...
I have a 97 civic EX and I plan on buying and swapping in a b18c1, within a few months.
Since I already have vtec I can just use the current wiring harness, right? No re-wiring needed....and Its just straight bolt in w/ some new mounts (a/c, rear tranny, and the driver side mount). Oh yeah , and I know I have to extend the primary o2 sensor wires, too.
...correct?
(Yeah I woulda searched but we all know its not working well right now)
Thanks a lot
[Modified by pdiggitydogg, 4:43 AM 4/3/2003]
Old Apr 2, 2003 | 07:39 PM
lazy bum shaughn's Avatar
Default Re: ok just confirm this for me... (pdiggitydogg)
What year is your GSR motor? I think you can use your current EX harness.
Old Apr 2, 2003 | 07:42 PM
Default Re: ok just confirm this for me... (lazy bum shaughn)
I was going to try and order one from 96-98 so the obd would match perfectly (nothing newer than 98 so not to get obd2.5/obd2b)
[Modified by pdiggitydogg, 6:27 AM 4/3/2003]
Old Apr 2, 2003 | 11:02 PM
Jackson's Avatar
It doesnt matter if it is newr than 98 unless you are talking about the ecu. You are going to have to do some wiring regardless. You will need to add the knock sensor plug and IAB sol. plug. Then the necessary changes to make it look nice and pretty. I am not sure on the ex harnesses, I have never messed with those, but on the dx harness you have to modify the ecu plug pins for the IACV,ie. move the a14 pin to a12.
Old Apr 3, 2003 | 11:53 AM
Default Re: ok just confirm this for me... (Jackson)
OK TTT I need more info...preferably from people that have done it w/ EX's
Old Apr 3, 2003 | 12:48 PM
Jackson's Avatar
You want someone to hold your hand too? I just gave you all the info you need.
Old Apr 3, 2003 | 03:24 PM
yeah sure man, you want the job
aceboog3x
Aug 21, 2008 10:24 AM
h22_crx
Jun 3, 2007 04:50 PM
phu
Dec 30, 2005 11:27 AM
B96v6
Dec 16, 2005 06:34 AM
Type-ARR
Oct 22, 2001 04:29 PM
