Skunk2 Camber Kit prep.
What exactly do you guys reccomend that I do to the Skunk2 kit to help it to not slip. I have read about taking a dremel to it to rough up the spots where the bolts contact the arm. Any other suggestions that you guys may have? Do you have any pics of a "slip-proof" kit?
I don't want it slipping at all
Also, after I get an allignment with the new kit installed, and I begin to make some camber changes, will I need to get an allignment after every adjustment? Are there clear dashes that indicate each degree of adjustment? Is it also safe to assume that changing the camber won't affect any other aspect of my allignment?
Thanks for any help.
- There are no markings to indicate different camber settings.
- You should have your car re-aligned everytime you change the camber.
I have been running with the stock Skunk2 hardware with this kit for a year now with some very agressive track sessions (some driven with an ex-pro race driver who was flogging the car VERY hard) without ANY slippage. I used locking compound on the screws and made sure they were good and tight.
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
