H22 vs. H23 Tranny
Old Apr 2, 2003 | 06:50 PM
BAZ's Avatar
BAZ
Default H22 vs. H23 Tranny
I'm just wondering what kinds of pros and cons I'd run into If I ran an H22 tranny on my Si. I'm just confused as to how each are geared. Also, what if I ran my H23 tranny with an H22 motor, Would this slow me down?
Does anybody have timeslips or any other info regarding their experience with these setups?
Old Apr 2, 2003 | 07:51 PM
1fast5gp's Avatar
Default Re: H22 vs. H23 Tranny (BAZ)
I don't think it will.. I know that the h22 tranny is one of the beefiest tranny honda makes.. well just the casing.. but the h23 tranny might be the same tranny.. but i'm not sure.. i havne't heard of any problems with it..
Old Apr 2, 2003 | 10:38 PM
b18bEG's Avatar
these are the gear ratios
H23 - H22 -
1st 3.31 1st 3.31
2nd 1.86 2nd 1.95
3rd 1.32 3rd 1.36
4th 1.03 4th 1.07
5th .81 5th 0.87
I have a h23 tranny on my h22, and honestly i like it better the gearing feels better. no time slips from before/after. it shouldnt slow you down..
Old Apr 3, 2003 | 01:51 PM
BAZ's Avatar
BAZ
Thanks for the responses.
So basically, I won't be turning out better timeslips with an H22 tranny
and a H22 motor With a H23 tranny won't be slowing me down in the quarter?
Also, in fifth gear on the freeway which tranny will Idle lower?
Old Apr 3, 2003 | 01:57 PM
satan_srv's Avatar
An H23 tranny on an H22a engine will defintely slow you down. Look at the gear ratios
Old Apr 3, 2003 | 02:00 PM
BAZ's Avatar
BAZ
Default Re: H22 vs. H23 Tranny (satan_srv)
what about freeway cruising?
and the H22 tranny is not really worth the investment unless I got a H22 motor to back it up huh?
Old Apr 4, 2003 | 08:27 PM
93ludeSi's Avatar
h23 is gonna give you a better top speed due to ratio aka lower rpm at highway speeds, it is designed to use the low end power of the h23 motor, vs the h22 tranny, better suited for the high rpm power of the h22 vtec
Old Apr 6, 2003 | 10:49 AM
BAZ's Avatar
BAZ
Default Re: H22 vs. H23 Tranny (93ludeSi)
so if i plan on really building and boosting the H23, I should just stick with the H23 tranny?
Old Apr 6, 2003 | 04:07 PM
93ludeSi's Avatar
yeah, from what I hear the h23 its the better tranny for a turbo
#1 luder
May 24, 2009 01:13 PM
live2ride31
Jan 29, 2007 12:03 PM
yeahdudebrown
Oct 15, 2004 03:46 PM
99spanishGT
Dec 24, 2003 08:02 PM
greenli0n25
Nov 25, 2003 11:01 PM
