Pulled the crx out for teh 1st time this year.....
91 crx si
rota rnr
jdm d15b
converted to OBD1
y8 intake manifold
10lb flywheel
act clutch
turbo kit in room
rota rnr
jdm d15b
converted to OBD1
y8 intake manifold
10lb flywheel
act clutch
turbo kit in room
looks almost just like my brothers did before the paint job and the wreck and the new wheels and so forth. looks good tho
i never pull out
*the $5 is figurative as WhiteEJOne has no money.
thansk for all the comments. its droped on tockio 5 way's and 350 rear coilovers and 450 front coilovers.
hey can you post some good shots of your intake manifold? I'm wondering how you hooked up everything on the Y8 manifold in an OBD1 car, cuz my friend and I are having some problems doing the same thing. Also, what throttle body are you using?
well i'm using teh y8 but i ahve a b16 one i'm going to put on. i put the AIT sensor in teh air box. i drilled a hole and used a gromet to seal it. you will need teh y8 throttle bracket. and you will una PCV valve custom way you'll see in teh pics... and i will take pics so you can see teh rest.
thansk again guys.... i would liek to get a CF hood and re paint my moldings black so it looks really clean...
actually we had to flip the Y8 throttle cable bracket over and bend it some to get it to work with the D15 throttle cable.
very nice...im trying to get my body too look like that...i need new fenders still...can i borrow yours...
[Modified by crxgator, 5:02 PM 4/3/2003]
