2003 v6 coupe hard to start...
Old Apr 2, 2003 | 05:56 PM
plg6886's Avatar
Default 2003 v6 coupe hard to start...please help!!!
I got my accord on feb 27, about a week or two later, I go to start it and I have to hold the key for more than 5 seconds sometimes to start it. There isn't a pattern, but it has happened close to 10 times. Anyone know what it could be?
Thanx
[Modified by plg6886, 3:12 AM 4/3/2003]
[Modified by plg6886, 3:13 AM 4/3/2003]
Old Apr 2, 2003 | 06:54 PM
dclub01's Avatar
Default Re: 2003 v6 coupe hard to start...please help!!! (plg6886)
If your starter is constantly working to start the engine during the entire 10 seconds, then it could probably be that your spark plugs may not be firing or that the process to go about that is not working properly... check them.
Old Apr 2, 2003 | 07:10 PM
Stripped Honda's Avatar
99-0104
Default Re: 2003 v6 coupe hard to start...please help!!! (dclub01)
its a brand new car you shouldnt have to look at the spark plugs take it back to the dealer
Old Apr 3, 2003 | 05:28 AM
lightningd's Avatar
Default Re: 2003 v6 coupe hard to start...please help!!! (Stripped Honda)
it could possibly be the check valve in the fuel pump. when you go to start the car next. turn the key to "on" and you should hear the fump pump cut on and build pressure. it will last for a few seconds. once the fuel pump cuts off, then turn the key to "start" and see what happens. if it starts fine when doing this everytime, then it's probably the check valve.
if the occurance is totally random it could be an exhaust leak somewhere, cause you to not have enough back pressure.
Old Apr 4, 2003 | 12:58 PM
AccordCoupe's Avatar
We can swap cars and you won't have that problem anymore!
Old Apr 4, 2003 | 02:06 PM
brycerocket's Avatar
heck plg6886, I'll swap cars with you I want a coupe instead of a sedan lol
Mrhodes18
Honda Civic (2001 - 2005)
Jun 10, 2015 03:52 PM
kadrian21
Jun 5, 2012 03:26 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
same ol' civic
Jun 5, 2005 07:29 AM
JBG's Ferio
Jul 31, 2003 09:14 AM
