turbo fit with radiator + fan crx
Old Apr 2, 2003 | 05:18 PM
DOHCRX's Avatar
Default turbo fit with radiator + fan crx
hey i just got a garett turbo for my crx and wanted to know if it is going to be enough room for the turbo considering the radiator is so big..i know it will be tight fitment but will it work?? thanks
Old Apr 2, 2003 | 06:36 PM
rioninja's Avatar
Default Re: turbo fit with radiator + fan crx (DOHCRX)
What did you get the turbo off of? or, what size is it?
I'm running a 60 trim t3, and i was able to fit everything with the stock radiator.
It really all depends on what manifold you use, make sure you get a mani thats
gonna place the turbo tight against the block.
Old Apr 2, 2003 | 07:07 PM
AVXHATCH's Avatar
Default Re: turbo fit with radiator + fan crx (rioninja)
can you drive turbo cars in the rain? I hear you should not drive turbo cars in the rain because The moist air will mess things up, ,is this true?
Old Apr 2, 2003 | 08:22 PM
Vtecless212's Avatar
Default Re: turbo fit with radiator + fan crx (B16A6rex)
i have drag 3 manifold with t3t4 and i used place racing front crossmember with 92-95 civic rad and a fan from autozone they work alot better than those fal fans my friend burned up 2 fal fans and never had a prob with autozone fan fo 40 $$
Old Apr 2, 2003 | 11:30 PM
Ri5e's Avatar
Default Re: turbo fit with radiator + fan crx (jdmturboef)
what I did was, i removed the A/C fan since there I took out my A/C
Old Apr 2, 2003 | 11:33 PM
qqqq
Guest
Posts: n/a
mine wont fit cause i have a maxrev mani and a t61 turbo so it all depends. just put it in and see.
Old Apr 3, 2003 | 02:55 AM
spiceisler's Avatar
What?????????? Don't they make turbo cars from the factory?
Old Apr 3, 2003 | 10:52 AM
DOHCRX's Avatar
Default Re: turbo fit with radiator + fan crx (clean90Si)
hey..whats a good manifold to have the turbo right against the block?? I got a 16g garret..
Old Apr 12, 2003 | 10:53 AM
RuffRhyno's Avatar
How come noone has suggested using the first gen Dodge Neon Radiator? It is a half rad and fits with the stock front crossmember...
Old Apr 12, 2003 | 02:49 PM
blah13's Avatar
Default Re: turbo fit with radiator + fan crx (RuffRhyno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuffRhyno &raquo;</TD></TR><TR><TD CLASS="quote">How come noone has suggested using the first gen Dodge Neon Radiator? It is a half rad and fits with the stock front crossmember...</TD></TR></TABLE>
Because, nobody wants a dodge neon anything in their car.
Old Apr 12, 2003 | 04:59 PM
WuShu's Avatar
New User
Default Re: turbo fit with radiator + fan crx (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
Because, nobody wants a dodge neon anything in their car. </TD></TR></TABLE>
radiators made by nippon denso, same company that makes radiators for crxs and which also makes a ton of stock parts for all imports.
Old Apr 12, 2003 | 05:01 PM
WuShu's Avatar
New User
i think ppl are skeptical of the neon radiator, ill take some pics of mines and do a how to in a day or two.
Old Apr 22, 2003 | 07:25 PM
redlineb18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean90Si &raquo;</TD></TR><TR><TD CLASS="quote">&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;ca n you drive turbo cars in the rain? I hear you should not drive turbo cars in the rain because The moist air will mess things up, ,is this true?&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
What?????????? Don't they make turbo cars from the factory? </TD></TR></TABLE>
yea, you can drive them in the rain, traction is at a minimum but it wont hurt the turbo.
90edhb
10
Oct 5, 2009 11:02 PM
AirWaveGT
Dec 1, 2004 03:32 PM
crix180
Mar 13, 2004 07:43 AM
Ri5e
Jun 19, 2002 07:47 PM
PROFILES2000
Oct 11, 2001 07:35 PM
