a/c system not hot nor cold??
Old Apr 2, 2003 | 04:59 PM
AGPSuperstar's Avatar
Default a/c system not hot nor cold??
im having issues with my air conditioning system...first, the air that it blows out is not hot or cold, even if i change the temperature setting, seems like it's just air from the outside coming in from the fan. another, when i switch from off to 1 or 2 on the climate control system, nothing happens....but when i turn it to 3 and 4, it works normally...what can be the problem?? i need a/c and in louisiana...i can not stand it without a/c...help me out guys...thanks agp
Old Apr 2, 2003 | 05:25 PM
SteveeeO's Avatar
Default Re: a/c system not hot nor cold?? (AGPSuperstar)
so your getting cold air when you switch it to 3 and 4? or is the temp the air blows out changing? if that's the case - check to see if your compressor is coming on, if it is - have your AC recharged
Old Apr 2, 2003 | 05:43 PM
Default Re: a/c system not hot nor cold?? (SteveeeO)
well....when i said normally, i meant that air comes out....switches 1 and 2 dont work but 3 and 4 work fine....still not hot or cold....sorry bout that bro
Old Apr 3, 2003 | 11:45 PM
any ideas guys??
Old Apr 4, 2003 | 12:36 AM
Vinceg99's Avatar
Well first your A/C probably needs to be recharged thats probably why the temp is like it is. As for your next problem with 1 and 2 not working I would be 99.999% sure that it would be your blower motor resistor. Its a little resistor that is behind your glove box that has 2 phillip screws holding it into the blower motor housing.Also it has a wire harness going into it. If you replace that I would almost gaurantee that your problem would be fixed. The part is about $25 bucks from Honda.
*EDIT* Another thing that you can check is that when you turn on your A/C make sure that the compressor clicks on. If it doesnt either the pressuse in the lines is too low or too high (you would have to figure out why on both accounts, if its low you could obviously have a leak if its high there could be a clog) but if it is too high or low there is a sensor in the A/C system that moniters this and it will make sure that the compressor doesnt engage so it doesnt wreck your compressor. You could try if it isnt clicking on to hard wire it to see if the compressor is even working or not if it is you would have to figure out the problem from there.
[Modified by Vinceg99, 3:43 AM 4/4/2003]
Old Apr 4, 2003 | 08:42 AM
Default Re: a/c system not hot nor cold?? (Vinceg99)
then how come my heater doesn't work?? sorry for all these questions but im new to this a/c stuff....thanks guys
Old Apr 4, 2003 | 10:36 AM
Vinceg99's Avatar
Oh so you cant get heat either?? Well then what that could be is if you look under your hood towards the firewall there will be the controls for the hot and cold selector. It a plastic piece that has the heater hoses going into it and there is a valve in it see if the cable is still attached to it and also maybe try moving it by hand to see if it moves (there will be like a lever on top where the cable should slide onto) And this piece is also bolted to the firewall as well I will see if I can find a pic of it for you.
leemcdaniel
Oct 17, 2010 06:29 AM
aust 97 coupe
Jan 3, 2009 05:21 AM
mynameizstitch
Mar 27, 2008 09:45 AM
PartiallyImmortal
Sep 30, 2004 01:39 PM
Prevail
Jun 22, 2003 06:33 PM
