ZC vs. Si Tranny (Turbo Application)
Old Apr 2, 2003 | 12:11 PM
88EF's Avatar
Default ZC vs. Si Tranny (Turbo Application)
Just wondering which tranny would be better for a turbo setup?
Old Apr 2, 2003 | 12:13 PM
Steve Berman's Avatar
Default Re: ZC vs. Si Tranny (88EF)
I always thought they were basically geard the same..
IM sure theres some differnce but, it cant be too much.
Old Apr 2, 2003 | 12:15 PM
88EF's Avatar
Default Re: ZC vs. Si Tranny (Steve Berman)
Reason I'm asking is, I have the opportunity to pick up both, and wanted to know which transmisson would be better suited for turbo.
Edit: Also, which axels do I use with the corresponding transmissions?
[Modified by 88EF, 3:29 PM 4/2/2003]
Old Apr 2, 2003 | 12:33 PM
Blue_Si03's Avatar
I too, thought they were the same. The gearing on the ZC (1-4)is shorter but the final drive is longer. While the Si's gears (1-4) are a little longer but have higher final drive.
Old Apr 2, 2003 | 12:46 PM
zCivic's Avatar
Default Re: ZC vs. Si Tranny (CRXracer89)
well I can help with the axle info....the ZC uses a intermediate shaft so use 90-91 integra axles. so you must have a SI, DX, EX or teg front hubs, If you have a STD/HF axles will not go thru. Si you can use any 4 gen axles but it depends on the outer CV and hub combos. HF/STD are smaller
[Modified by zCivic, 4:50 PM 4/2/2003]
Old Apr 2, 2003 | 12:54 PM
tpr's Avatar
tpr
The Si gearbox is geared slightly higher (less rpm at a given speed) while the zc is a bit buzzy at highway speeds. Mine tached at 4k RPM = 70 MPH. I went back to the SI and it tachs at 3.k RPM = 70 MPH. If you want a quick launch add the SI final drive to ZC and it will be really quick off the line but will be taching very high at highway speeds. I have not ever run a turbo but i understand it likes a taller gear (lower RPM) but thats only what I have read on this site. Anybody know for sure.
Old Apr 2, 2003 | 01:07 PM
Urban Business
Guest
Posts: n/a
Default Re: ZC vs. Si Tranny (tpr)
however with the higher r's your eliminating a lot of potential turbo lag
88EF's Avatar
That being said I guess I'll go with the Si tranny...
loudes13
Jun 9, 2009 07:19 PM
Spazius
Jun 16, 2007 02:03 PM
teewhy55
Sep 6, 2005 12:12 AM
nudvl
Jan 27, 2005 05:19 AM
Aphrodavid
12
Nov 11, 2002 06:09 AM
