Beeping when turning the key to ON
Old Apr 2, 2003 | 11:17 AM
RedGSR's Avatar
Default Beeping when turning the key to ON
My 99 GSR just did something weird. When I turn the key to ON, it beep 5 times (or 6 give or take). I tried it a couple times and it would beep every single time I turn the key to ON. Then I drove my car back home and tested it again and it stopped beepping. I called Acura customer care and they don't know anything about this beeping. Does anyone know what the beeping means?
Old Apr 2, 2003 | 11:58 AM
IC x Prince's Avatar
New User
Default Re: Beeping when turning the key to ON (RedGSR)
do you have a factory alarm? it might have something to do with that.
Old Apr 2, 2003 | 12:15 PM
GSRacer1's Avatar
your accessory fuse could be blown check the fuses under your dash its either the ignition fuse or most likely acc fuse
Old Apr 2, 2003 | 01:16 PM
RedGSR's Avatar
I have an Ungo Alarm.
I checked all the fuse and they seem fine.
The car will run fine, but just that it is weird how it would beep 6 times. It also seems like when the car is cold, it will beep. When the car is hot, it will stop beeping.
Old Apr 3, 2003 | 10:38 AM
roadrunner's Avatar
In US cars, the beeping occurs when you don't have your safety belts fastened. If they are fastened and you turn the switch from ACC to ON, it won't beep.
Pr0j3cT95dX
16
Apr 1, 2011 12:26 PM
chelt_scene
Apr 17, 2009 09:38 AM
Dropmy Si
Honda Civic (2006 - 2015)
Oct 2, 2008 10:31 AM
mike93eh
Apr 28, 2005 12:59 PM
BrandonClaps
Nov 17, 2002 04:55 PM
