Brown top ZC info???
Old Apr 2, 2003 | 10:38 AM
Drew Peacock's Avatar
Default Brown top ZC info???
There is a guy selling a Brown top ZC engine has forged low comp HKS pistons and includes inlet manifold and other things..
I have a zc sohc or D16a6, I am wondering if the Brown top ZC internals and other things are interchangable at all???
Any help is good, I tried a quick search and didn't have much luck. Cheers:D
Old Apr 2, 2003 | 10:57 AM
zCivic's Avatar
Default Re: Brown top ZC info??? (turbozxi)
yeah a brown top is a D series so you can use everything except the block, intake manifold and motor mounts. So it wont bolt in to your chassis but you can use rods, pistons, crank pretty much the internal from the block but you gonna have a funky c/r. if you go with ZC rods or pistons in a SOHC d series will raise c/r some, so what his C/R is its gonna be lower if your using your rods or if you use his rods it gonna be higher. Cranks I know can be used but specs I'm not postive about
Old Apr 2, 2003 | 08:49 PM
Default Re: Brown top ZC info??? (zCivic)
Hey thanks for that man! Do you know of a webpage that has any spec's on the ZC brown top?
SFlCrx
Nov 26, 2007 05:51 PM
TurboHondaGuy
May 16, 2006 02:43 PM
miketurbohonda
Apr 10, 2004 06:39 PM
Ham'ed Hatch
Nov 12, 2002 06:53 AM
