ZC tranny on a D16z6?? will it work?
Old Apr 2, 2003 | 09:34 AM
Toptul_Honda's Avatar
New User
Default ZC tranny on a D16z6?? will it work?
Will this work?
The Zc tranny has 3 mouting points for a midshaft for use of equal length to reduce torque steer.
I want to know if the d16z6 has 3 mounting points (under the oil filter) for bolting of the midshaft
Heres a pic of the zc block
SOmeone is selling a hybrid ZC tranny and i want to jump on the opporutinity if it will work on a d16z6
"You can't just use regular Si axles with the tranny either unless you replace
the differential with an Si one. "
i got this from the email of the guy whos selling the tranny
[Modified by G2-Rex, 11:01 AM 4/2/2003]
[Modified by G2-Rex, 11:20 PM 4/2/2003]
Old Apr 2, 2003 | 09:43 AM
kyle h.'s Avatar
Default Re: ZC tranny on a D16z6?? will it work? (G2-Rex)
my d16a6 has that. dunno if that helps at all.
d15b2
d16a6
editicture for reference..
[Modified by kyle h., 6:56 PM 4/2/2003]
Old Apr 2, 2003 | 10:00 AM
New User
Default Re: ZC tranny on a D16z6?? will it work? (kyle h.)
not really... a pic of a d16z6 would help
Old Apr 2, 2003 | 10:13 AM
kyle h.'s Avatar
oh, you are buying the tranny? and the tranny is going on a z6? it shouldnt matter. just use the braket thats on the back of your motor.
Old Apr 2, 2003 | 10:15 AM
New User
i think it does matter, because the intermdeiate shaft is supposed to go onto tthe block
Old Apr 2, 2003 | 12:46 PM
Katman's Avatar
Will this work?
It depends.
Not all Z6's have tapped intermediate-shaft mounting holes. Supposedly on the '92 short blocks have those tapped holes.....while later (93-95) have untapped holes...but the holes are there.
I was going to build up a high compression Z6 for an EG civic; I picked up a Hydro ZC tranny which uses complete integra axles & half-shaft and works on the Z6 block I have (since it has the tapped half-shaft holes)....but the project is currently on the back burner.
AND yes, if its a true ZC transmssion where it be a cable or (rare) hydro version, the differential is made for a bigger axle.. IE> integra axles<
The hydro ZC tranny I have is for sale too, if you're interested; although I'm not sure what year your car is. If you own an 88-91 civic/crx it obviously won't work.
Old Apr 2, 2003 | 10:22 PM
New User
Default Re: ZC tranny on a D16z6?? will it work? (Katman)
i might buy a tranny off somene locally thats a hybrid ZC
so who knows. are you sure about the 92 having taps?
the engine is coming out of a 93 civic si...
Old Apr 3, 2003 | 08:58 AM
Katman's Avatar
what's 'hybrid' about the tranny?
is it a ZC tranny with an Si (4.25) final drive?
I'm sure about my 92 Z6 block having taps.....im not sure if every single one has taps. Check the Z6 yer about to buy though..
Old Apr 3, 2003 | 09:55 AM
New User
yup its a Zc tranny with the Si 5th gear and SI final drive (4.25)
actually found out that it might work out! so im going to check out the motor and decide
Old Apr 3, 2003 | 12:32 PM
Katman's Avatar
cool deal.
That tranny has some fun acceleration.
Just make sure you have the right clutch & flywheel combo to make everything work like butta.
Old Apr 3, 2003 | 03:35 PM
New User
yup i hope so
SwissChEz82
Jun 9, 2009 10:53 AM
JurakS
May 20, 2003 04:02 AM
Toptul_Honda
16
Apr 4, 2003 11:47 AM
MIZIKETSK
Oct 28, 2002 01:17 AM
