ZC tranny on d16z6 block?
Will this work?
The Zc tranny has 3 mouting points for a midshaft for use of equal length to reduce torque steer.
I want to know if the d16z6 has 3 mounting points (under the oil filter) for bolting of the midshaft
Heres a pic of the zc block
SOmeone is selling a hybrid ZC tranny and i want to jump on the opporutinity if it will work on a d16z6
"You can't just use regular Si axles with the tranny either unless you replace
the differential with an Si one. "
i got this from the email of the guy whos selling the tranny
[Modified by G2-Rex, 10:59 AM 4/2/2003]
[Modified by G2-Rex, 11:18 PM 4/2/2003]
Heres a pic of the zc blockSOmeone is selling a hybrid ZC tranny and i want to jump on the opporutinity if it will work on a d16z6
I am pretty sure it doesn't , but you can still use the ZC tranny , just use the d-series axles. one short and one long.
[Modified by Proelite103, 12:57 PM 4/2/2003]
ok heres the deal
The JDM Z6 which is a sohc ZC vtec has the mounting holes and they are threaded for the intermidiate shaft I use this set up. The intermidiate shaft is NOT the same as the one that goes on the dohc ZC the bracket has a angle on it that is different.
The local Z6's(usdm z6) THAT I HAVE seen have the holes but they are not threaded for the bolts.
The local A6 blocks have the holes and are threaded.
and yeah you have to use 90-91 teg axles...thats what I use
[Modified by 89civicdx, 11:10 AM 4/2/2003]
you might get lucky...if the motor is in the car just jack up the car and use a finger or a bolt and see honda does some weird things sometimes.
There was no need to thhread the us motors as the cars were assembled here
and the 92+civics didn't use the 3piece axles
but check anyways
from what I have seen...no
but check anyways
The Z6 (93 I think) I had only had 2 holes and a dimple for the one over the oil gallery, and neither of the holes had threads. Drilled and tapped and the black-top ZC intermediate shaft fit right. Don't drill the dimple too deep, or you're Jed Clampett. Use 90-93 Integra axles, remove hub rings and outer rubber ring.
you can use the mounting bracket of the 86-89 Integra but only 2 of 3 mounting points will work
the top half of the bracket will have to be hacked off and the bottom 2 holes will work with the USDM block
I have pics i scored off of FF squad of what im talking about
Post Email addy and i can send you pics
can you post the pics here? i am considering this down the road, because i have a zc tranny with lsd, and i would really like to use it on another motor.
i actually found out that that the 92 had taps in it as someone did a ZC swap with a d16z6. and theere was also a 95 d16z6 that had the holes.........
god i hope this works!
Trust me you should just check your block for the holes...don't rely on everyone else for this or you are setting yourself up for dissapointment...you'll go buy the tranny then find out this and that doesn't line up or you gotta tap this...then you'll be pissed
AllmotorGSReg
Sep 21, 2008 01:50 PM
Sirex
Apr 5, 2003 09:29 AM
