need some expertise please.
car starts, but just doesnt turnover, ive performed tests on the ignitor, and coil , and also swapped distributors, everything is good in that aspect. where should i check next? relay? where is the main relay located on the 97accord lx 2.2no tec?
thanks,
j
thanks,
j
how can it start if it doesn't even turn over?...
I'm thinking flaky wiring connections somewhere. Or maybe the CYP, TDC or whatever sensors in the distributor.
Yeah when you turn the key to the on position, you should hear the fuel pump turn on for a few seconds. If you don't, the Main relay is bad. It is comon for this to be an intermittent problem, especially in hot weather.
Check out these links for more info:
http://autorepair.about.com/library/diy/bl_hmr-1.htm
http://autorepair.about.com/library/.../aa010301a.htm
http://www.markl.f9.co.uk/howto/elec...main-relay.htm
How bout the starter? Does it click? What if you hold the key to START, does it continue to click? If so, your starter is locked up, time for a new one.
its jus not startin the car period, starts intermittently, but when it doesnt start, i have no spark at all. maybe its not sending a signal out to the ignition? when it starts thers spark on all 4 cyli. ive already checked the obvious.
Does u dash light up normally when in acc?? If not then ur ignition could be stuffed up under the steering wheel. Try turning the key all the way and then turning it back just a little bit, that might help
smokez187
Aug 10, 2007 11:35 AM
MetalKill
10
Jan 30, 2003 07:42 AM
