NEDIV National Tour Back On
Being that Fed Ex is my local site, I am going to issue some advice. I would reserve an hotel between DC and Baltimore. Not right near the event site. This is not a very secure area. This is not that far to travel. Also on the same thought process, you will not want to leave anything at the event site overnight as you can at most other National event locations. In fact, I am not even sure you will be premitted to leave anything overnight. Expect to do some up hill walking. The majority of the lot is on a decent slope (assuming they use the same lot that we run on which I am sure they will).
I am sure I will think of other stuff later. Hope to see you all there.
Eric
Eric
As somebody who stumbled across the general "neighborhood" looking for gas off the DC Beltway on my way home from Petersburg last year, I'll add that I've never been in an area that looked so OK, but gave off as many bad vibes. And I'm someone who has spent mucho time in da Bronx, Brooklyn, and similarly urban parts of Jersey.
Are there any decent places to stay out on Route 50, heading towards Annapolis? That may be a little closer than heading up towards Baltimore.
[Modified by preparedcivic, 6:33 PM 4/2/2003]
Rock ON! Finally, an event I can go to that doesn't require a hotel and a 8+ hour drive! Way to go WDCR! How did they get past the 60 day cancellation stuff?
Andy - who's finger is poised over the mouse button ready to register...
As for off rte. 50, I would look for a place by Bowie. That is probably not a bad area. Anywhere between Bowie and Annapolis is fine.
Eric,
FANTASTIC! Me vs. you on your turf... If those Truechoice Koni's hold up (they're being looked at as we speak with only 2 events on them!
Anthony "Mario" Crea
What is FedEx Field like.
Surface? I assume asphalt
What sort of courses can you set up?
Here are a few pics from last year. http://solo.wdcr-scca.org/2002pic.htm
Also if you look at some of the pics ajn has posted I am sure you will find some more.
Had to do it.
here are some links to pictures I took last year.
http://www.imagestation.com/album/pi...?id=4291959321
http://www.imagestation.com/album/pi...?id=4291886225
http://www.imagestation.com/album/pi...?id=4291846959
http://www.imagestation.com/album/pi...?id=4291671147
http://www.imagestation.com/album/pi...?id=4291618273
aj
TY
TY
Typical courses are about 60 seconds.
First portion of course is typically uphill - if you planned to install a header or perform some dyno testing, I suggest getting it done before the FedEx event. My nearly stock RX-7 wheezed like an 80 year old with emphezyma at the start of a few courses.
On a completly different note :
Is there any reason to be worried about the softer sprung cars with R tires on all that off camber stuff? just curious.... not that I'll have that problem personally even tho my car is pretty softly sprung.
[Modified by MWatkins, 2:28 PM 4/3/2003]
I can second that... last time I was there I remember a couple of the shifter Karts were REAL slow on the launch (I could have launched faster in tennis shoes). A good strong launch was definitly a good thing. Torque! Torque! Torque! Torque!
They were not 125 shifters. I don't think they were shifters at all.
No more than usual - it tends to be the quick transitions (slalom) that upset cars. The camber changes at FedEx are not usually abrupt (you'd have to really be mean and design the course that way).
Edit: Fawk! Track weekend at Slummit Point on the same dates. Goddammit.
What time does a FATT usually wrap up?
aj
SM 30 Hatch
Apr 6, 2004 04:46 AM
Ross
Nov 5, 2001 07:26 PM
