what width wheel for racing slicks
I'm thinking I'd like to try out "real" race tires, I meen Goodyear or Hoosier slicks, not the DOT tires.
I assume all of these tires are the cantelevered design, so what tire would be desirable for a 2300 lb car and what size rim does it need to go on?
Thanks,
Scott
Thanks,
Scott
I'm going to try out some 23x9x15 Goodyear slicks this weekend. I think they're mounted on 15x7 wheels. In the past I've run on 20x9.5x13 on 13x7 wheels.
Thanks...
Just looked at Hoosier's website and they specify about a 7" wide wheel for all the 9" wide slics, that's probably the ticket then.
Next question, do the slicks like a wider tire? It looks like a 13x8 might be easier to come by.
Cantalevered tires typically have less rim width dimensional tolerence than street radials - they are designed for a specific wheel width and you will want to find out from the manufacturer what width(s) are acceptable.
Kirk
Kirk
The Hoosier website will give this info. For example the 20/9.5-13's on my Civic are on 7's; in DP or Road Race FP trim on 6's I would run 20/8-13's.
Scott, I assume this is for your dinosaur tech RWD Celica? What you got for spring rate in that? If it is enought i would suggest something like 23/9.5-15's on 7's.
I just got my new ones yesturday. http://www.midatlanticmotorsport.com
Tom will tell you the compound is dependent on car weight, but sent me
r25a all around. Eh, last year I ran r35 fronts, but didn't use them up completely.
This is in a ~1725 pound civic. (i know, heavy...)
Right now I'm running 350 lb springs up front with a 24mm (stock) sway bar, and 225 lb springs in the rear with no sway bar.
I have a set of 500 lb springs for the front if needed, and can order any rate I want for the rear for about $90 per pair (Afco circle track springs), if I can find the rates I want used, then I save a few bucks. Too bad the circle track guys tend not to sell springs in matched pairs.
Scott
93delsol
19
May 15, 2002 03:40 PM
