which gen si gauges are these?
Old Jun 19, 2001 | 05:51 PM
utensil's Avatar
New User
Default which gen si gauges are these?
ditto:
they seem like the newer si's, so in order to do this would i have to cutomley put them in?
Old Jun 19, 2001 | 06:07 PM
Smurf's Avatar
New User
Default Re: which gen si gauges are these? (utensil)
The speedometer looks like it was taken from a 96-00 SOHC Civic and the two outter guages are from the Si.
Old Jun 19, 2001 | 07:09 PM
Powered by Honda's Avatar
Default Re: which gen si gauges are these? (Smurf)
Yup, what he said...
Old Jun 19, 2001 | 07:11 PM
utensil's Avatar
New User
so are u saying the cluster from an eg and he just used different faces for the gauges?
Old Jun 19, 2001 | 07:14 PM
No, the cluster is not from an EG. That guy Dylan from FF Squad, used the temp/fuel gauge and tach from a 99-00 Si. The speedometer is from a 96-00 SOHC EK. He had to custom fit those gauges in an EG, it is probably not worth the trouble for you to do what he did. Basically, he put put together a cluster meant for an EK, but instead, put it in his EG...
Old Jun 19, 2001 | 10:15 PM
euclidEH3's Avatar
New User
Default Re: which gen si gauges are these? (MugenHondaFormula1)
the reason he did this is because he ordered a spoon prepped engine and ECM, and the stuff they sent him was all OBD II. So, he switched out the entire wiring harness from and EK.. At least thats what it says on one of Katmans older sights.
Old Jun 19, 2001 | 11:44 PM
utensil's Avatar
New User
Default Re: which gen si gauges are these? (JHMeg8)
what makes it so hard to do?
Old Jun 20, 2001 | 12:23 AM
airon's Avatar
it fits but then it has some gaps and you can tell from the pic its not flush, yeah like he said on the FF site they tell you how he has a spoon prepped motor
spoon_concept_eg6
Apr 4, 2008 02:15 AM
CTR-GSR
Nov 17, 2005 04:42 AM
Dasavior
Mar 11, 2004 06:36 AM
Asian G
Jan 29, 2004 06:03 PM
KevronsEG
Jun 28, 2003 08:52 AM
