Pinout Diagram d16y8
Old Apr 2, 2003 | 04:53 AM
devonic's Avatar
Default Mini Me Help Need Pinout Diagram d16y8
I did a mini me swap a while back(d16y7 97 civic dx block but with a 98ex vtec head and IM) and i think it was liam831? that posted a picture of where i wire the vtec stuff too. I had made a printout of it but can't find it now and i was wondering if anyone might have it, i searched on here but my old posts weren't found. btw my car is an auto ( )
I had originally used a 98ex wire harness but after some problems with it i put my dx back in and stripped the wires i needed from the EX harness. I have them wired up but not sure if i put them in the right spot cause when i hooked my ex ecu up last night my idle went crazy, but i think it might be cause i wired the knock sensor to the wrong spot(and the engine retards if its not found)
and another question
i wired up the knock sensor but theres a brown colored plug a little above the ecu plugs. what is that for? one of the knock sensor wires on the ex harness was on that brown connector but in its spot on the dx harness there is a wire already there. can i splice that wire and wire in the knock sensor or is it not really needed there?
thanks
[Modified by devonic, 1:54 PM 4/2/2003]
[Modified by devonic, 1:58 PM 4/2/2003]
[Modified by devonic, 2:16 PM 4/2/2003]
Old Apr 2, 2003 | 05:21 AM
devonic's Avatar
Default Re: Mini Me Help Need Pinout Diagram d16y8 (devonic)
bump so it doesnt get buried!
Old Apr 2, 2003 | 05:29 AM
eg6ajk's Avatar
this might help you out a little.
Old Apr 2, 2003 | 05:54 AM
devonic's Avatar
Default Re: Mini Me Help Need Pinout Diagram d16y8 (eg6ajk)
that helped a little
when doing a mini me swap what are the wires you have to run again? my brain is fogging up as i sit and try to go over this in my head at work...
if possible wire colors?
Old Apr 2, 2003 | 06:20 AM
devonic's Avatar
bump!
Old Apr 2, 2003 | 07:28 AM
devonic's Avatar
Old Apr 2, 2003 | 08:11 AM
devonic's Avatar
ttt
runnyray
Apr 30, 2011 07:32 AM
Civiclx
Mar 18, 2004 08:58 AM
Civiclx
30
Jan 31, 2004 10:12 PM
devonic
10
Apr 9, 2003 09:53 AM
yobless
Apr 22, 2002 08:10 AM
