Youre a Honda pimp if you can figure this out!!!!
Old Apr 1, 2003 | 11:52 PM
JDMjdawg's Avatar
Default Youre a Honda pimp if you can figure this out!!!!
Hi, I have an ek with a jdm obd2 b16a. My question is, what would cause my tach to stop working? I have an si cluster. My car threw a check engine, it was vss (vehicle speed sensor). Took out the speed sensor and cleaned it, no code, but still no working tach. I've checked the connections to the cluster, theyre all good. Can anyone name off anything that could be causing this. Please help, I need to see what the hell I'm revving my motor to!!! Thanks guys
Old Apr 1, 2003 | 11:55 PM
GTlvr82's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (JDMjdawg)
Just maybe your VSS is dead??? Check all wiring going to and from the VSS and get a voltmeter to see if it is indeed the VSS...find a Helms and see what the resistance/current is supposed to be for it and see if yours measures up. Just my .02...get more opinions...Lord knows I don't wanna F your ish up.
Old Apr 2, 2003 | 12:18 AM
JDMjdawg's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (GTlvr82)
Cool, thanks for your info. If the vss was dead though, wouldnt I not get any reading for my mph? Hmm......Are there any wires on the dis. that could be grounded out somewhere? What other wires are tach related? I know that there is the blue wire that is by the harness on the drivers side, that wire is the tach signal I think. What is that little cap on the end of the wire that has that rubber cover over it. Could that little plastic cap have anything to do with it? Thanks
Old Apr 2, 2003 | 12:36 AM
GTlvr82's Avatar
SOMEone has a wiring diagram of this ish...and I think you are right about the VSS and your speedometer. If no one responds that knows more go by a Helms or one of those vehicle books at Rice Zone or Rice Boys ...There are wiring diagrams in the back of the book.
Old Apr 2, 2003 | 01:33 AM
mysideperformance's Avatar
check your fuses?
Old Apr 2, 2003 | 03:11 AM
Russ713's Avatar
dAng!
Default Re: Youre a Honda pimp if you can figure this out!!!! (mysideperformance)
the tach runs through your ignition, check connections, wires, etc...
Old Apr 2, 2003 | 03:15 AM
Steve Berman's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (Black Light)
lol. I painted my needles on my cluster red. It took two days before the needles would stop sticking to the little plastic pin that holds them @ 0. I would have to thump my cluster to make them work .... There fine now.. I just thought id mention it because you never know..
Old Apr 2, 2003 | 04:59 AM
Frosty_spl's Avatar
Take off your distributor cap and make sure the blue wire is pushed in all the way.
Old Apr 2, 2003 | 05:38 AM
JALOP B16's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (Frosty_SPL)
Exactly It prob came loose inside the dis
Old Apr 2, 2003 | 06:17 AM
Patron's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (JALOP B16)
make sure the tracers on the gauge cluster haven't been severed, and make sure you're not missing any bulbs, you may not get a signal if the current isn't completed.
Old Apr 2, 2003 | 06:18 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Youre a Honda pimp if you can figure this out!!!! (ptran13)
Your VSS may not be dead (you aren't getting any codes right). But I would swap it out with a known good on and try it again.
Old Apr 2, 2003 | 06:27 AM
JALOP B16's Avatar
That wouldn't matter he just would be missing some light.
Old Apr 2, 2003 | 06:31 AM
Patron's Avatar
Nope, had the problem with a JDM GSR cluster, the tach didn't work, there was a severed tracer and a bulb missing, we followed the pinout and followed the tracer and it was indeed the tach tracer that was severed with a missing bulb, we pulled a bulb from another cluster popped it in and the tach worked.
Old Apr 2, 2003 | 11:01 AM
JDMjdawg's Avatar
Thanks for the info guys. Checked the bulbs already, but havent checked the distrubutor. I'll do that right now and let you know if that solves my problem. Do you guys think that the tach on my cluster could have just takin a ****? I'll have to borrow my friends EX cluster and see if his works......
Old Apr 2, 2003 | 11:12 AM
bjaeyang's Avatar
wut code are you getting??? If its a p1298 it deals with vss, o2 sensor, etc. If thats correct then its ur alternator. I had the code 1298 a few weeks back and it turned out to be the alternator. I
Old Apr 2, 2003 | 11:23 AM
JDMjdawg's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (bjaeyang)
the code was #17, VSS.
Old Apr 2, 2003 | 11:34 AM
JDMjdawg's Avatar
So you think it could be my alternator? I know that when my car idles and the lights are on, the lights dim a bit. Didnt think that could cause my tach to stop working. Hmmm.........
Old Apr 2, 2003 | 11:49 AM
fowler!'s Avatar
Did you rewire your distributor at all? That is most likely the cause of this mess.
Old Apr 2, 2003 | 11:51 AM
euclid's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (fowler)
first things first, i think you should find another cluster to try out, if it still doesnt work then it will tell you its not the cluster
then you can go from there
Old Apr 2, 2003 | 12:07 PM
bjaeyang's Avatar
its ur alternator for shure. Mine did the same except it threw some more codes. when ur lights are on at night it dims in and out right? It mess w/ ur speed sensor because its all electrical. Check your alternator/sp sensor fuse under dash on driver side. it should be a 7.5. that should be blown. Put in a new one and it will work but act real funny then fuse will blow again.
Imma HONDA pimp now. hahhaha
When i had this problem no one on this damn board would help me out. But im glad i can help u.
JDMjdawg's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (euclid)
Yeah, I need to borrow my friends cluster tonight. I've been meaning to, but havent had the chance. As for the distributor, I havent touched it at all.
If the problem is my cluster, is there any way to get a new tach needle and components and then just change that out? I don't wanna have to buy a new cluster.
Old Apr 2, 2003 | 04:01 PM
JDMjdawg's Avatar
bump
Old Apr 2, 2003 | 09:12 PM
built562's Avatar
how does your car run? i was always told that the ecu reads from the tach for vtec activation and other signals.
Old Apr 2, 2003 | 10:06 PM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: Youre a Honda pimp if you can figure this out!!!! (Steve Berman)
hahaha i did that to my cluster and i was in sac this weekend and it was freaking HOT. the paint got stuck to the needles at 0. i was like WTF?!?! i had no tach or speedo and i couldnt figure out why. then after a few seconds it went back to normal. ha. just thought i'd share that
Old Apr 2, 2003 | 10:15 PM
Nameless RB26's Avatar
Default Re: Youre a Honda pimp if you can figure this out!!!! (eeJayeiGht)
when you cleaned it.. did you remove that little pin inside it?
