Got rear LCAs, got GSR swaybar, what else do I need?
Old Apr 1, 2003 | 07:43 PM
ryanhook's Avatar
Default Got rear LCAs, got GSR swaybar, what else do I need?
Usually I can find my answer without having to post but I can't find this one in my searches.
I've got a 93 Si coupe (that's an EX to you guys in the US) and I'm having my suspension done this weekend... I'm adding a GSR swaybar and urethane bushings too.
Now I've got a set of rear LCAs from an Integra, and I've got a GSR rear swaybar with endlinks, but exactly what other parts do I need?
Which parts should I pick up from the Acura dealer? Subframe brackets, bolts, etc. If you've got part numbers that would be great too.
Any help would be greatly appreciated.
Old Apr 2, 2003 | 02:31 PM
ryanhook's Avatar
Default Re: Got rear LCAs, got GSR swaybar, what else do I need? (ryanhook)
TTT. I can't believe no one has the answer.
Old Apr 2, 2003 | 02:49 PM
racecarpete's Avatar
that's everything you need. The swaybar, endlinks, brackets, and bolts, you should also look into some form of reinforcement kit like a beaks kit.
Old Apr 2, 2003 | 03:28 PM
ryanhook's Avatar
Default Re: Got rear LCAs, got GSR swaybar, what else do I need? (SilverCivic2k)
Alright thanks. I was more after the actual part numbers but I'll find that hopefully.
As for the reinforcement kit, for a GSR swaybar I don't think it's necessary. If I move up to an ITR bar then I could see the need.
Old May 7, 2003 | 08:07 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I'm going to be getting a very very cheap GSR rear swaybar set-up w/ all the hardware on Friday.
A SRK is *not* needed with such a small swaybar, correct?
Anyone?
Old May 7, 2003 | 08:34 PM
slowboy's Avatar
Default Re: Got rear LCAs, got GSR swaybar, what else do I need? (SkyeC)
I had the GSR rear sway bar on my coupe for a year with no problems
Old May 7, 2003 | 09:24 PM
.hugo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to be getting a very very cheap GSR rear swaybar set-up w/ all the hardware on Friday.
Anyone?
Nope it should be fine without a SRK, you only need it for bigger bars like the itr.
Old May 8, 2003 | 04:09 AM
ryanhook's Avatar
Default Re: Got rear LCAs, got GSR swaybar, what else do I need? (starang)
I've been running the car for close to a month now with the rear swaybar. I've definitely noticed a difference (even with the stock GSR bar) on the autocross track. The install was easy.
Old May 8, 2003 | 06:04 AM
BROOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
As for the reinforcement kit, for a GSR swaybar I don't think it's necessary. If I move up to an ITR bar then I could see the need.</TD></TR></TABLE>
For others researching this swap later on: I'd still use the Beaks or BSQ reguardless of which sway bar, it is not much more money than buying the oem brackets (new), which I think are junk anyways. Good luck on the swap
Modified by SLPR at 1:05 PM 5/8/2003
Old May 8, 2003 | 11:58 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: Got rear LCAs, got GSR swaybar, what else do I need? (SLPR)
Well, I'm getting everything for $30. The SRK is like twice that.
JDubya
Sep 28, 2002 03:06 PM
todds94teg
Jul 24, 2002 07:28 AM
DSC
Apr 15, 2002 07:52 AM
Pressurized
Nov 28, 2001 03:09 PM
