dx to mpfi fuel injector ?s
id really prefer for some one whos had this expirience to answer, when doing the dx to mpfi on a zc motor from left to right does it matter what two plugs the original dual injector connections go to, if so which ones do i connect them to from left to right (left being closest to the distributor cap).
from left to right, which is cylinder #4 to cylinder #1 - #4, yellow injector wire - #3, blue injector wire connects to red DX injector wire - #2, red injector wire - #1, brown injector wire connects to yellow DX injector wire
Injectors and injector resistor box
Connect the yellow/black wires from the two DX injector harnesses and run it to the yellow/black wire on the injector resistor box.
Connect the yellow wire from the DX injector to the #1 injector (brown wire).
Connect the red wire from the DX injector and run it to the #3 injector (blue wire).
Connect the A3 wire to the #2 injector (red wire).
Connect the A7 wire to the #4 injector (yellow wire).
Connect the 4 red/black wires from injector resistor box to each injector.
http://www.hybridgarage.com/tech/4gt...-zc-wiring.htm
[Modified by ZC_CRX, 10:43 AM 4/2/2003]
beatthisspeed69
May 8, 2006 06:14 PM
Tippyman
14
Mar 27, 2006 08:55 PM
