Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
are these pads still usable for hpde?
Old Apr 1, 2003 | 06:52 PM
magic hat #9's Avatar
Default are these pads still usable for hpde?
how thin can you run a race pad before it becomes unsafe? i have these panther+ pads that have successfully burned my fluid and slightly warped my rotors. the pad wear looks even and still functions normally. i about to embark on a 2 day hpde at beaverun; i will have new cobalt race pads with me.
Old Apr 1, 2003 | 07:08 PM
ReflexGTI's Avatar
Default Re: are these pads still usable for hpde? (magic hat #9)
I don't think they'll make it through 2 days. Carbotechs are riveted and you're pretty close to the rivets.
Old Apr 1, 2003 | 07:11 PM
Track rat's Avatar
Default Re: are these pads still usable for hpde? (ReflexGTI)
Looks like 3-4 sessions left, if you're lucky.
Old Apr 1, 2003 | 07:18 PM
smokin rubber's Avatar
run the new pads and keep those for back-ups. I have a set of P+ that look just like that after two weekends. ~5hrs
Old Apr 1, 2003 | 07:21 PM
Willard's Avatar
Since you have the unfortunate pleasure of rivets... run them till they touch and then keep wearing.
left one looks a bit iffy.
Old Apr 2, 2003 | 08:41 AM
gsirnj's Avatar
Default Re: are these pads still usable for hpde? (Willard)
If I had pads out alread... and have new ones on hand... I would just install them in. 1) Better safe than not... 2) I'd rather relax and hang out at the track than try to spend the 1/2 - 1 hour (rushing) to put them on before the next session.
[Modified by gsirnj, 5:43 PM 4/2/2003]
Old Apr 2, 2003 | 09:16 AM
Crack Monkey's Avatar
SInce the brakes are apart, use the new ones and keep the pictured pads for backup. The pictured pads have a few sessions left, but probably not a whole weekend.
Old Apr 2, 2003 | 09:58 AM
577HondaPrelude's Avatar
Default Re: are these pads still usable for hpde? (Crack Monkey)
what day will you be at beaverun? I will be up there this weekend. Fri/sat, for the cannon ball run event.
Old Apr 2, 2003 | 10:06 AM
Evan55's Avatar
my XPs worked great all the way to the backing plate.
I would say you have about a day, maybe 1.5-2 if you dont brake hard.
the pads will start to smell more as they get very low.
Old Apr 2, 2003 | 11:00 AM
emwavey's Avatar
... i have these panther+ pads that have successfully burned my fluid and slightly warped my rotors. the pad wear looks even and still functions normally. ...
If it were me, I'd change the pad, replace the rotors and bleed the system through with new DOT 4 fluid, but that's just me.
Old Apr 2, 2003 | 11:28 AM
alu95's Avatar
Default Re: are these pads still usable for hpde? (elgorey)
Won't this score the rotors? Or do you consider them wear items? I have a set that looks like that.
-al
Old Apr 2, 2003 | 02:37 PM
Gennady's Avatar
New User
Default Re: are these pads still usable for hpde? (alu95)
How do you know you have 'slightly warped' rotors?
To me, slightly warped rotors is like being 'slightly pregnant.'
Old Apr 2, 2003 | 04:06 PM
jc836's Avatar
I think you answered the question actually. The coin is not a good indicator-but the rivets are. Time for new pads if you want to be optimum. You state there was an issue with the brake fljuid-change it when you do the pads. Temps should be a bit lower with new (my experience anyway) and the pedal should stay up.
Old Apr 2, 2003 | 04:18 PM
MaddMatt's Avatar
Default Re: are these pads still usable for hpde? (jc836)
Yep, those are *just* about done. Probably a 2-3 sessions at most. Now would be a good time to call me for more since we have a ~10 sets being made right now.
Other brake manufacturers (Hawk, PFC, etc) recommend that when there is ~.125" of material left, the pads should be tossed, or else you risk delamination and/or getting too much heat into the caliper thereby boiling your fluid. The head of the rivets of our pads are ~.125" above the backing plate. So if you follow the advice of the very well known and respected brake manufacuteres, you'll never have issues with rivets in Carbotech pads because when you get to them, it's time to toss them.
Matt
Old Apr 2, 2003 | 04:51 PM
siisgood00's Avatar
New User
Default Re: are these pads still usable for hpde? (MaddMatt)
Also remember as the pads become thinner, they wear a lot faster. Less pad=less thermal capacity=faster wear rates.
Like everyone else said, I would put the new pads on. I would just say go ahead and wear the pictured pads down, but you need to let the car sit a good 30 min or so (of prescious track time) to let everything cool down as to not snap a wheel stud or the caliper bolt. That caliper bolt especially dosent like to be messed with when its pipin' hot.
Just curious, what Cobalt pads you gots?
Old Apr 2, 2003 | 08:01 PM
REFLUX's Avatar
Default Re: are these pads still usable for hpde? (siisgood00)
if he uses up these current pads & has to replace them while at the track (assuming he uses the same kind of pads but new ones), would he need to bed them in??
or would he be able to just throw them on & race some more?
Old Apr 2, 2003 | 08:03 PM
.RJ's Avatar
.RJ
Default Re: are these pads still usable for hpde? (REFLUX)
all high-performance pads (metallic) are going to need to be bedded in.
TurboEM1
May 14, 2006 07:18 PM
nonsense
May 19, 2005 01:30 AM
rice r0cket
Nov 22, 2003 07:38 AM
magic hat #9
Apr 2, 2003 07:49 AM
