cheapest but best way to lower?
Old Apr 1, 2003 | 09:15 AM
FalconMan's Avatar
Default cheapest but best way to lower?
what is it.
Old Apr 1, 2003 | 09:24 AM
IloveNewt's Avatar
Default Re: cheapest but best way to lower? (FalconMan)
cheap and best dont work together.
Old Apr 1, 2003 | 09:30 AM
Boostless97Lude
Guest
Posts: n/a
what is it.
lower what?
Old Apr 1, 2003 | 09:52 AM
FalconMan's Avatar
Default Re: cheapest but best way to lower? (EX-Boosted97Lude)
92 si
Old Apr 1, 2003 | 09:55 AM
One Slow Lude's Avatar
what is it.
lower what?
i am assuming he means his car
cheapest is cuttin the springs but i would never do that, and highly recommend not doign that
other than that buy just lowering springs, which arent that much, and using stock shocks, but the ride uiality could suck real bad and blow the shocks out quick
Old Apr 1, 2003 | 09:59 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: cheapest but best way to lower? (POSlude97)
damn it, i was think comression ratio, i swear i was... i am to much of an FI nut i guess
Old Apr 1, 2003 | 10:07 AM
HA HA HA, he might have been, i was just guessing. thats good though, i didnt even pick up on that one
Old Apr 1, 2003 | 10:54 AM
HailRedskins's Avatar
H&R Sport Springs 1.5 inch drop (About $135)
KYB AGX Shocks (Got mine on ebay for $70 a shock)
or you could go with KYB GR2 shocks (even cheaper I think $50 each from Tirerack.com)
KYB doesn't recommend going lower than 1.5 inches tho so... H&R sports were my choice, but if you want to go a tad lower go with the Eibach pros ($200 i think)
You could go cheaper and just get springs, but you'll prematurely wear out ur stock shocks (a few months maybe) Your call. I did lots of research before I chose my setup. Good luck.
[Modified by neoGTR22, 8:26 PM 4/1/2003]
Old Apr 1, 2003 | 11:06 AM
Default Re: cheapest but best way to lower? (neoGTR22)
i just got my H&R sports and konis put in, it doesnt look like no 1.5 on my car though. i had to lower the front koni perch cause the back was lower now its slightly higher but not noticable......but it still didnt look all that lowered to me, what about you?
Old Apr 1, 2003 | 11:07 AM
ludesleep's Avatar
or you can go have your springs compressed and have spot welds made on each side of the springs
Old Apr 1, 2003 | 11:31 AM
itr-j's Avatar
Default Re: cheapest but best way to lower? (ludesleep)
buy some coilovesr
in the long run its cheaper
92shade
Suspension & Brakes
Jan 4, 2008 08:05 PM
devgon2
Aug 15, 2007 03:50 AM
xiongf
40
Jun 6, 2006 11:16 PM
eymnewdc4
Dec 2, 2004 11:28 AM
turbo4racing
Apr 29, 2003 11:01 AM
