92 GSR real trailer arms?
I got a full 92 GSR suspension. I'm doing the 4 wheel disk brake swap on my 90 hatch. The rear GSR trailer arms will bolt up to my car correct? I also have the GSR e-brake cables too. Which e-brake cables do I need to use? Any other advice on this or pics from those of you who have done it?
It all bolts up, use the GS-R e-brake cable adn brake lines, and its all peachy
. Just unbolt the trailing arm, brake line, then remove e-brake cables then install is in reverse
[Modified by zCivic, 3:52 PM 4/1/2003]
. Just unbolt the trailing arm, brake line, then remove e-brake cables then install is in reverse[Modified by zCivic, 3:52 PM 4/1/2003]
Thanks. I didn't want to get it all apart and find out that I may be missing a part or something. So I need to use the GSR cables or do I use the Civic e-brake cables?
gs-r they designed differed to work with the calipers instead of drums. On the GS-R caables there u shaped and have a dowel pin with a cotter key, while the drums its just a block on the end
[Modified by zCivic, 4:43 PM 4/1/2003]
dck1ng69
Jan 1, 2018 12:57 PM
