Fuel Pump location 93 Accord
Old Apr 1, 2003 | 06:49 AM
jlicks12's Avatar
Default Fuel Pump location 93 Accord
Can someone tell me where the fuel pump is located on a 93 accord??
Thanks
Old Apr 1, 2003 | 07:26 AM
greensleeper's Avatar
Default Re: Fuel Pump location 93 Accord (jlicks12)
in your gas tank. look under your trunk mat between the shock towers. bam. you're there.
[Modified by greensleeper, 10:27 AM 4/1/2003]
Old Apr 1, 2003 | 10:07 PM
iam7head's Avatar
Default Re: Fuel Pump location 93 Accord (greensleeper)
dont you need to drop the tank for 5th gen and older gen?
Old Apr 2, 2003 | 05:19 AM
Default Re: Fuel Pump location 93 Accord (iam7head)
I didn't say he could get it out. But that's where he'll find it.
Old Apr 2, 2003 | 05:26 AM
lightningd's Avatar
i'm not sure why you're asking this, but if you fuel pump is having trouble cutting on when you turn the ignition to "on" it could be the fuel pump relay, not the actually fuel pump. My relay went bad on my 5th gen
Old Apr 2, 2003 | 07:48 AM
jlicks12's Avatar
Default Re: Fuel Pump location 93 Accord (lightningd)
Ok- The first thing I checked was spark and voila- none there. The plugs are saturated with raw fuel, and there is an odor of gas at the tailpipe so I'm assuming the pump's ok. I downloaded from autozone the procedure for checking the ignition module and coil, and have yet to do that. People are also saying that the crank sensor on these model accords are notorious for going bad, and most other forums the guys are showing the same symptoms- drive a few miles and the car suddenly dies.
First things first, i guess
definetly getting wasted after this
ULNAFARKIN
Jul 19, 2015 02:49 AM
Jaynik
Oct 22, 2010 04:55 PM
joeyt
Honda Civic (2001 - 2005)
10
Dec 24, 2008 10:40 AM
moo32moo32
Aug 11, 2008 12:38 PM
Stroker
May 7, 2006 06:46 PM
