B series tranny ? in an EF
Old Apr 1, 2003 | 05:31 AM
Hondasaurs's Avatar
Default B series tranny ? in an EF
I have a B17A1 in swapping into my 1990 hatch. On the tranny, where the speedomoter cable goes, there are two lines. They look like oil lines or something. Where do these hook up to and what are they?
Old Apr 1, 2003 | 06:46 AM
sleeper4dr's Avatar
Default Re: B series tranny ? in an EF (ZC_CRX)
take a ~5" hose, bend it into a U-shape and fit it over both of the holes on your speedo housing. those lines are originally there to be hooked up to power steering lines if i remember correctly, but you definitely do NOT have to hook them up.
Old Apr 1, 2003 | 06:58 AM
REDBARON's Avatar
Default Re: B series tranny ? in an EF (sleeper4dr)
You're correct on the lines, but I've heard that you're supposed to use your old speedometer gear...? I could be wrong though.
Old Apr 1, 2003 | 07:03 AM
Hondasaurs's Avatar
Thanks! I'm about ready to drop it into my car. I just got to finish this wireing nightmare of ODB0-ODB1 now.
Old Apr 1, 2003 | 07:05 AM
sleeper4dr's Avatar
Default Re: B series tranny ? in an EF (REDBARON)
my old JDM S1 and GSR YS1 trans speedo gears looked identical to me but i swapped mine out because of my Kaaz even if you were supposed to change them out (to maybe maintain the correct gearing for your speedo?) the difference is barely noticeable.
Old Apr 1, 2003 | 07:31 AM
Hondasaurs's Avatar
So my speedo cable should be fine then?
Old Apr 1, 2003 | 07:58 AM
sleeper4dr's Avatar
definitely
Old Apr 1, 2003 | 08:11 AM
Buzz Kill's Avatar
They are oil lines related to the power steering in the orginal car and are not needed. The power steering was variable assist based on the speed of the car. As the car sped up, the oil pressure would build and lessen the assist from the power steering.
Old Apr 1, 2003 | 09:47 AM
ScottEK's Avatar
I was told similar, when I asked they said to get rubber caps from the hardware store, I'm sure both methods would work the same.
crazypot4200
Nov 16, 2007 02:26 PM
GroundZer0 336
Sep 10, 2006 06:11 AM
Rywire
17
Jul 29, 2004 11:32 AM
Garrett
Apr 4, 2004 06:06 PM
rice_classic
Jul 4, 2002 08:14 PM
