what clutch is needed for zc tranny?
Just got my zc tranny yesterday....now I need to replace my clutch on my 89 crx. I will be using the zc tranny on the d16a6. my question is what clutch, flywheel, and pressure plate do I need to make it work? Any help is appreciate it. Thanks.
you will want to use the clutch, flywheel and pressure plate for the year of the tranny. although if your tranny is an 89-91, you will probably want to use a 90-91 clutch, flywheel and pressure plate as those years use a bigger diameter clutch disc.
edit: i am talking about the crx/civic application when i talk about the years. the zc tranny can run the crx/civic clutch, flywheel and pp.
Deo
Apr 3, 2007 03:56 PM
phatrick2332
Mar 31, 2004 06:11 AM
Ronin Panda
15
May 11, 2003 05:05 PM
FourthGenHatch
11
Apr 16, 2003 06:43 PM
