price 4 cams
Old Apr 1, 2003 | 01:36 AM
LSpimpTEC's Avatar
Default price 4 cams
does anyone know if skunk2 cams are actually worth the $600-$700. Should i save for them or are itr/ctr cams a better "bang for buck"? Has anyone used both and can tell a substantial difference?
Old Apr 1, 2003 | 03:45 AM
JD_B18CDX's Avatar
Default Re: price 4 cams (LSpimpTEC)
Skunk2s are a little more aggressive. Without tuning and bolt ons to improve air flow, it will bog for a while when you hit vtec. (at least on my GSR motor).
There is really not much choice.
After you are done with intake and exhaust (headers and cat back), the next thing to modify to improve air flow are the cams.
[Modified by JD_B18CDX, 7:47 AM 4/1/2003]
Old Apr 1, 2003 | 05:56 AM
pennies_hatchie's Avatar
Default Re: price 4 cams (JD_B18CDX)
its gonna cost you more than just 600-700 at the end. depending on which stage of cams you get, to really use the skunk2 cams, you have to upgrade your valvetrain as well (valves, retainers, springs) and get good cam gears. then you'll have to dyno and tune it, which again will cost money. so you better have a lot change if you want to properly use and take advantage of the more aggressive cams. but at the end, you'll be more satisfied with the skunk2 over the itr/ctr cams IMO
B20VTECLUDE
May 8, 2010 08:32 PM
eg6madness
45
Dec 30, 2007 06:19 PM
teggy182
Mar 26, 2006 09:01 PM
B18C-EJ1
Apr 14, 2002 07:53 PM
GSlowR
Sep 7, 2001 08:30 PM
