Stay with Tanbe's Coilvoers or Koni with Ground Control ? ( I want stiffer ride)
Old Mar 31, 2003 | 11:25 PM
Showoff's Avatar
Default Stay with Tanbe's Coilvoers or Koni with Ground Control ? ( I want stiffer ride)
I have Tanabe Sustec pro SS coilovers on a 1995 accord ( reson on this forum is system almost the same sorry guys ) should i stay with them or get Koni shocks with Ground Control coil overs sleeves with stiffer spring rates ? reson Looking for a stiff ride , its stiff as is bit still little bounce, or should i just get stiffer spring rates on the Tanabe's ? anyone heard of any problems with tanabe's or anything ?
Thank you in advance
List of suspension parts that have so far- Tanabe Full coiloves Ssutec Pro SS,
S-T way bars front and back, DC sport upper strut bar, DC sport rear Lower Tie bar, 18x7.5 rims with 215/35/zr in front and 225/35/zr in the back
Old Apr 1, 2003 | 11:14 AM
ApexiAccord's Avatar
Default Re: Stay with Tanbe's Coilvoers or Koni with Ground Control ? (Showoff)
id stick with the tanabes which ones do you have the SUSTEC PROS?
Old Apr 1, 2003 | 11:25 AM
DsITR's Avatar
Default Re: Stay with Tanbe's Coilvoers or Koni with Ground Control ? (ApexiAccord)
The advantage to the GC's is you could call and order custom rates..(they could give you advice as well.)
Im not sure you could get custom rates on the Tanabes...If you can, I would prolly go that route, since you already have the dampers..
Old Apr 1, 2003 | 08:51 PM
Showoff's Avatar
Default Re: Stay with Tanbe's Coilvoers or Koni with Ground Control ? (dsludefosho)
well so far planing to stay with tanabe and get stiffer spring rates, the guy in tanabe doing me a favor of selling direct to me and get me the pieces with out buying pairs etc planing do get stiffer spring rates and new front shocks try it out then if anything go with Koni with GC
Eg2707
17
Jan 12, 2007 08:14 AM
G2DAB18
Oct 20, 2005 09:16 AM
Bay_707
Suspension & Brakes
25
Aug 7, 2005 06:10 PM
Understeer
Jul 16, 2003 11:21 PM
fiebru1119
Apr 23, 2002 07:35 AM
