b16 studder
ok, i've done many b16 swaps and never had this happen before... everything is done and wired got jdm b16 in crx si ran the vtec ect. ect. and when i hit the gas there is a very bad hesatation(?). all the vaccum lines are correct, fuel pressure ok, tps ok, air idle control valve ok, what else to check? thanks for any help provided
[Modified by jdmturboef, 9:59 PM 3/31/2003]
If youve done many b16 swaps then I would assume you have the read the valve cover. VTEC not vtech. All aside, was the car fully warmed up before you took off, if not the o2 sensors were causing it to run way rich, thus resulting in hesitation. Hopes this helps, just depends on the o2 sensor, older ones are worse.
I dont think so. It only happens after ive been cruising on the hwy for a while and it actually goes away ABOVE 4000 rpms? A friend of mine had a GS-R motor swapped into his CRX at the same shop that did mine and it does the same thing. The other way to fix it is to shut the car off (while cruising at hwy speed) and turn it back on. Resetting the ecu seems to fix it. If I remember, it was throwing a code for the O2 sensor.
I just switched the two wires from the o2's going to the ECU and it solved my problem. Were you having this problem at constant throttle? That is when it was the worst on mine, felt like it was going to blow up.
hey mikeee did you change the timing belt on the motor could be a tooth off or just check the timing
hurry up and finish that car so the boost can come out
i'm trying to get the boosted ef done but i keep waiting on more and more parts you feel my pain.. i just ordered my place racing front crossmember everything else is almost ready to go
