CX w/ CRV motor - gas mileage?
Old Mar 31, 2003 | 06:39 PM
sparq's Avatar
Default CX w/ CRV motor - gas mileage?
Stock CRV mileage is 22 city / 25 highway.
If it was dropped into a CX - how much improvement would it be over the stock output? The CX weighs 1032lbs LESS then the CRV, I would imagien the differance would be alot.
Tried searching, didnt find anything... anyone?
Old Mar 31, 2003 | 06:50 PM
nsxmatt's Avatar
Default Re: CX w/ CRV motor - gas mileage? (sparq)
I would guess it would be about 5 mpg better. In any case it wouldn't be that bad
Old Mar 31, 2003 | 06:58 PM
sparq's Avatar
Default Re: CX w/ CRV motor - gas mileage? (nsxmatt)
Well im just curious, because I know if the car was PULLING 1032 pounds, it would be more then a 5 mpg differance.
Old Mar 31, 2003 | 07:18 PM
SlippylesKB's Avatar
My bro had a B20/Vtec w/ LS Tranny and he frequently saw 400+ w/ his setup per tank
Scott
Old Mar 31, 2003 | 07:25 PM
t0p_sh0tta's Avatar
Default Re: CX w/ CRV motor - gas mileage? (SlippylesKB)
wow.... I was hard pressed to get over 200 per tank with a stock 93 Ex.
Old Mar 31, 2003 | 08:13 PM
andrew dc's Avatar
Default Re: CX w/ CRV motor - gas mileage? (t0p_sh0tta)
I hear the CX has a smaller gas tank...
I pulled 32 mpg freeway with my b18b and 98 spec itr tranny 4.40 FD
Old Mar 31, 2003 | 08:16 PM
Who Said's Avatar
i think most of it will depend on the driver...but its a honda so you know your looking at 25+
Old Mar 31, 2003 | 08:18 PM
Yea, I was quite amazed at the mileage when he told me. I barely get 200 w/ my stock CX motor, but that could also be because every single gasket you can think of is spent
Scott
Old Mar 31, 2003 | 11:10 PM
sparq's Avatar
Yeah the CX tank is only 10 gallons vs. 11.9 gallons like the other cars... Thanks for the info guys!
Old Apr 1, 2003 | 01:42 AM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
my cx holds 12 gallons.
Old Apr 1, 2003 | 02:29 AM
sparq's Avatar
Default Re: CX w/ CRV motor - gas mileage? (VitaminB20)
Im sure it does, thats probably tank size + reserve.... Actual printed material says its only 10 gallons though. (probably has to do with the CX being a light weight "gas sipper" model - they say the tanks smaller because that extra two gallons of gas would add 16 lbs )
Old May 3, 2003 | 03:50 PM
b20guy's Avatar
This is weird, I'm running a b20z with gsr tranny in a 96 hatch, and I'm embarassed to say I'm getting 18.5 mpg mixed driving. I got 195 miles on my tank this week, and I took it fairly easy. I checked the plugs, they seem normal, (not white, not black) but an even gray color....anyone know why its so crappy for me? 45 psi fuel, sk2 intake, only code is evap, so i guess those fumes aren't getting burnt.
daymkimchee
Dec 23, 2009 12:56 PM
bear3721
Honda Motorcycles
Jun 12, 2008 06:04 PM
Honda_Tech01
Mar 29, 2008 05:32 PM
TheCiscoKid
16
Jan 22, 2004 05:27 PM
silverEH2
13
Apr 3, 2003 12:24 PM
