Accord Engine Swap
Old Mar 31, 2003 | 06:32 PM
AccordTypeR6's Avatar
Default Accord Engine Swap
I want to swap an Accord EX engine into my 94 LX. But I don't have the EX ecu. Can I use my stock ECU? How can I get V-Tec to activate? Could I find an EX ecu at a Honda dealership? Or would a VAFC Vtec controller be enough? Would I need a laptop or that? Any help would be greatly appreciated.
Old Mar 31, 2003 | 06:42 PM
Kataku2K3's Avatar
Default Re: Accord Engine Swap (AccordTypeR6)
Get a VTEC ECU... I'm sure that you'll be able to find one if you ask around... Dealership = $$$$$ A VAFC will not do anything for ya... You need to run it inline with a VTEC ECU... You could also get away with an rpm activated switch tho I would not recommend it... A VTEC ECU is programmed with low/high cam timing/fuel maps which affect how the motor runs... This is just to say that your EX motor will make less power running an LX ECU with a rpm activated switch... What year is your car??? Good Luck
Old Mar 31, 2003 | 06:44 PM
sslude's Avatar
okay, lets say you have a non-vtec motor and you want to swap in a vtec motor. you have to have a vtec ECU to make vtec work. VAFC only tunes your fuel and lets you set your vtec engagement and disengagement points. you can still use a VAFC without vtec, the only difference is that you would only be setting the fuel and when hooking it up, you wouldnt have a vtec wire. you dont need a laptop for vtec or a VAFC. maybe for like a wild setup, you might want a AEM EMS, which is on the laptop. so yes, if you want vtec your'e gonna need a new ECU, your'e gonna need a new one anyways.
[Modified by sslude, 7:46 PM 3/31/2003]
[Modified by sslude, 7:47 PM 3/31/2003]
Frankyh23a1
Apr 29, 2018 01:54 PM
romeodepaz
Jan 5, 2014 10:30 PM
SpdMongrel
Oct 16, 2012 06:15 PM
vtechaccord
Mar 14, 2011 03:03 PM
skud_dusty
Mar 26, 2003 10:20 AM
