D16Z6 in 89 CRX SI hell to get right
I did this swap 2 weekends ago
got a D16Z6 with p and p head valvejob and slight milling
dropped it in and used my manifold, diz, and ECU
no vtec activation yet
its SLOW AS HELL????
Im certain VTEC is gonna help some
anyways
Do I need to convert the whole tihng over to OBD1
or just get a vtec controller????
lol Im desperate fellas I even tried to engage vtec with a switch wired to the solenoid
(failed)
I have tye manifold and injectors for it
Someone mentioned a conversion harness
I dont wanna go into rewiring any dash parts
advice?????
anyways
(failed)
advice?????
u CAN use the Z6 intake manifold... with the OBD electronics. using a PM6....
and yes without VTEC the engine its slow as hell.... after 4800k rpms u dont have any power wasoever.....
just get a MSD switch for now... it will work as a temporary til u go either OBD1 or VAFC....then u will see the difference
I wonder why vtec didnt engage when I wired it to a hot switch on the dash?
incorrect voltage????
I jusr ran a hot SWITCH to the ONE WIRE of the solenoid
left the oil pressure wires alone
drove down the rode easy to 2nd gear then stomped it at 5000 flipped switch and NOTHING
[Modified by Civic Racer X 7, 10:23 PM 3/31/2003]
Well did you just put the motor together or what? My freinds Y8 was just rebuilt and at slow it was slow as dirt, then after we broke it in and started getting on it, it got quicker, plus he has an apex vtec controller and all. But anyway do you have the timeing correct? Make sure EVERYTHING is right.
yea Its got new rings in it so its sorta fresh I guess
It seems to get a lil quicker than when I first was driving it but I didnt expect slower lol
Ill try to see if I hear the CLICK tomorrow
THX for all u guys help
damn you guys are FAST and helpful
Glad I was referred here
So you guys think a the setup I have now with a VAFC
would be just as good as a complete P28 setup??
considering I could prollly compensate for the fuel map but is the lack of that timing map a big deal???
anyone rechip ECU's??????
but with a VAFC u got more room for tunning and expandin the power.... so i say Pg7 and a VAFC
wow man I hooked up the solenoid on a switch today
got going in 2nd gear 4000 rpms
floored it when I saw 5000 I hit the switch
Its almost no different than before lol
and yes it CLICKS
and yes it CLICKS
i have a zdyne b16a one wire conversion used it in my z6 swap and it ripped now i have a zc in there i'm selling the ecu make offer
kenjief8
Dec 27, 2004 06:58 AM
project dc2
Dec 24, 2002 06:49 AM
